Will it fit with no problem??
Old Jun 23, 2014 | 01:31 AM
mingc08's Avatar
mingc08
Js got my 2011 ipl. looking foward to getting a new setup for wheel and tires soon but dont know to which sizes will fit without rubber, etc at stock height. no drop yet.
i was looking at wheels that are
20x9.5 offset +25
20x 10.5 offset + 45
tires 255/30/20 front
305/25/20 rear
should i have to worry about any problems with this setup?
Old Jun 23, 2014 | 08:19 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by mingc08
Js got my 2011 ipl. looking foward to getting a new setup for wheel and tires soon but dont know to which sizes will fit without rubber, etc at stock height. no drop yet. i was looking at wheels that are 20x9.5 offset +25 20x 10.5 offset + 45 tires 255/30/20 front 305/25/20 rear should i have to worry about any problems with this setup?
Those are sedan offsets, you'll be fairly sunken in. Also, 20" wheels without a drop look silly (opinion), and will make your car look like a 4x4.
If you're asking if they'll rub or anything, then no, I don't think they will.
Old Jun 23, 2014 | 09:56 AM
Sunny G's Avatar
Sunny G
Without the drop they will stick out, but depending on how much you lower your car they will fit. You may have to trim the fender bolt to avoid rubbing
Old Jun 23, 2014 | 10:38 AM
GoFightNguyen
Because Racecar
Sedan offsets on a coupe should be sunken in, no? I don't think you'll have to worry about poking out, quite the opposite.
Coupe offsets are something like +15 front, +25 rear.
Old Jun 23, 2014 | 11:50 AM
speedracer g37's Avatar
speedracer g37
The front sounds flush, the rear sounds sunken in. Also, wouldn't 305 on 10.5 with a 45 offset cause problems on the inner side with suspension?
Old Jun 23, 2014 | 04:52 PM
Yes, there will be interference w/ the lower arm w/ that much positive offset.
2012G37
Jun 3, 2018 06:59 PM
Clutch34
Sep 14, 2015 03:26 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
slawek65
Sep 8, 2015 09:07 AM
