Help G37x Akebono Brake Installation
Old May 31, 2014 | 11:15 PM
JPat94's Avatar
JPat94
I think he's talking about the banjo bolts.
Old Jun 3, 2014 | 05:18 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
You need shorter banjo bolts though...
Old Jun 3, 2014 | 06:00 PM
ChinkyChoy's Avatar
ChinkyChoy
if you keep your stock lines you will need shorter banjo bolts
Old Jun 3, 2014 | 06:30 PM
Motoboat's Avatar
Motoboat
How do you know what bolts you need? So it depends on the brake line? So if i get aftermarket SS ones when i upgrade, can i use the ones off of the sport brake diagram, or do i need different ones? Sounds like i need to do more research.
Old Jun 3, 2014 | 07:15 PM
warped ideas's Avatar
warped ideas
A quarter past stripped
I bought my Akebono BBK from Concept Z Performance. $1801.20 after shipping. The kit comes with everything that is needed in order to make the swap. You have the choice to buy the fluid and SS brake lines along with the type of rotors and pads you want. I would go with Concept Z and DIY. The install really isn't as hard as you would think. Hell, installing the HFCs are more tricky then this.
Old Jul 1, 2015 | 01:54 PM
TheLocNar's Avatar
TheLocNar
PX wants $400 for the install now. Damn. lol
Looks like I'll find some friends willing to tackle this with me.
Originally Posted by Ryne
I paid $300 to have the Akebonos installed and they supplied brake fluid. I feel that is a pretty fair price since the job requires modifying the front and rear dust shields, replacing the calipers/rotors/pads, and bleeding the brake system. I was concerned with the banjo bolts and wanted to make sure my braking system was done correctly without any leaks. I was also worried about damaging the paint on the caliper with brake fluid etc. I figured that threading a bolt hole or ruining a caliper's paint would have easily set me back more than $300. Anyways, I was going to Project X regardless to have my car lowered and aligned so I was able to get it all taken care of in a single visit. I have also run into many shops that won't touch aftermarket parts; the key is finding a shop that specializes in aftermarket installs, preferably Nissan/Infiniti like Project X.
Rex- 3 pints is plenty
G's
Nov 5, 2023 12:01 PM
TheLocNar
Aug 16, 2015 07:14 PM
connoisseurr
Aug 16, 2015 04:26 PM
Ihtbealexxx
Aug 9, 2015 03:30 AM
