setup for G37X Coupe
Old Mar 25, 2014 | 12:44 AM
mark1478's Avatar
mark1478
Just purchased some works and just want to make sure I get the correct setup. I did do a search, and i got a number of different answers but wanted to get additional input with the sizes, offsets, and drop of my car.
Im dropped on eibachs, rear camber kit. Wheels are work durandals 20 x 8.5 +38 front and 20 x 10 + 38 Rear. I dont know if i plan on coiling next year or not just because the roads here are awful. any opinions appreciated!
Old Mar 25, 2014 | 06:49 AM
Darth Kinetic's Avatar
Darth Kinetic
Tires have to be within 1% of oem rolling diameter and generally Xs have a square setup because of awd...
Use this to get tire size within 1%
http://www.1010tires.com/Tools/Tire-Size-Calculator
Old Mar 25, 2014 | 08:52 AM
THE most compatible 20" staggered tire size for an x are 245/35/20F
285/30/20Rear, if that's too much rear tire for clearance then 235/35/20F
275/30/20R you can use the 245 on that combo in front but you'll be right at the 1% edge, the 235/275 set is much less than that front to back.
Old Mar 25, 2014 | 10:02 AM
Darth Kinetic
Thx B! What does that make the rim widths come out to?
Old Mar 25, 2014 | 02:43 PM
mark1478's Avatar
mark1478
Wouldn't mind doing the 285 option but how would I know if I got enough clearance? Thanks for the help
Old Mar 25, 2014 | 04:19 PM
235s on a 7.5-8.5"
245 8-9"
275 9-10"
285 9-10.5"
Old Mar 25, 2014 | 04:20 PM
If you're offsets are OK on your wheels you can run the 285s.
Old Mar 28, 2014 | 05:59 PM
mark1478's Avatar
mark1478
my offsets are 38 each. am i good?
Mattlorentzoe
May 24, 2021 08:49 PM
G37xhibeet
Nov 15, 2016 09:29 AM
dAgent
Dec 1, 2015 09:03 PM
timc00k
Sep 5, 2015 05:12 PM
