Help Will stock G37s tires fit these wheels?
Old Mar 14, 2013 | 12:12 AM
Brainchild's Avatar
Brainchild
I'm no expert when it comes to wheel/tire fitments so I need help from fellow wheel aficionados.
Will the stock tires on a G37S wheel fit wheels with these specs? How will it look? Stretched?
Front: 19X8.5; 35mm offset
Rear: 19X9.5; 40mm offset
Thanks in advance.
Old Mar 14, 2013 | 06:18 AM
BosMaSwaG37's Avatar
BosMaSwaG37
Absolutely, .5 isn't going to make much of a difference at all. Might even look better. It would hardly be a stretch.
Old Mar 14, 2013 | 10:09 AM
Brainchild's Avatar
Brainchild
Thanks for the help!
Im actually looking at another set with specs as follows:
Front: 19x9.5; 20mm offset
Rear: 19x11; 18mm offset
How will these look and what tire size would you recommend for a clean and trouble-free fit?
Old Mar 14, 2013 | 12:32 PM
BosMaSwaG37
On the rear, hell no lol. I mean that would be a hell of a stretch...and an unnecessary stretch. Your offsets are a bit aggressive. I have a 9.5 and I am running 235/30 and on my 10.5 rear I am running 255/30. My offsets are +20 all around. My setup is a comparable and somewhat conservative for a stretch. If I were running your numbers I'd run a 265/30 on that rear or maybe a 275/30 depending on how low you like it. I like my car to be low so when I'm choosing tires I don't go for the wider tires.
Old Mar 14, 2013 | 03:58 PM
Brainchild's Avatar
Brainchild
I didn't mean i was planning on using the stock tires on these wheels. I know they wont fit so i need to find out what size tires i need for a flush fit. Im lowered on Eibach springs and don't plan on going any lower. Will the wheels stick out with these specs?
Old Mar 16, 2013 | 02:35 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
The oe tire scenario in your initial post will be fine. If you want to run an 11" in the rear I would go 245/40-19 285/35-19.
Mattlorentzoe
May 24, 2021 08:49 PM
james6980
Oct 9, 2015 01:28 PM
mitchlt
Aug 20, 2015 03:44 PM
ddayeg37s
Aug 9, 2015 07:10 PM
Hiryuu
Aug 7, 2015 07:08 PM
