I Apologize.. I have an offset question
Old Feb 28, 2013 | 10:23 AM
MJD41985's Avatar
MJD41985
Hey Guys,
I have a 2011 G37 RWD.... I'm looking at a set of 20" Vossen wheels. They are 10.5" in the rear with 285 30 15 treads and the front it 8.5" with 245 30 15. The offset is 37. I plan on buying an eibach lowering kit. Will this fit? Will it rub?
Thanks in advance. I'm sure there are a bunch of write ups on this already. I'm sorry I didn't search, I just need an answer asap.
Old Feb 28, 2013 | 10:37 AM
Sunny G's Avatar
Sunny G
Maybe your search is coming up empty because you have your tire sizes wrong. It should be 245/35/20 and 285/30/20. I've had Vossen CV3 installed on my car before for test fitting offsets and if you have a sedan with no drop then you can fit the following offsets with out any issues 20x9 +32 and 20x10.5 +45 on the tire sizes listed above. When you lower your car the rears will be flush and there shouldn't be any rubbing. You don't have to worry about the front since there is a lot of space all around and there will be no rubbing. Let me know if you have more questions.
Old Feb 28, 2013 | 10:41 AM
OB G's Avatar
OB G
yes, search is your friend. there's a whole thread for vossen wheels.
fronts will be fine. also, are you sure it's a 8.5" wheel? didn't even know they made that. what's the offset in the rear?
Old Feb 28, 2013 | 11:21 AM
MJD41985's Avatar
MJD41985
Wow... Rookie error on my part 245/35/20 and 285/30/20 is the tire size... He told me the offset was 37
Old Feb 28, 2013 | 11:34 AM
Robert_K's Avatar
Robert_K
Vossen has done so many G37s I would contact them directly.
Old Feb 28, 2013 | 01:51 PM
Diego@Vossen's Avatar
Diego@Vossen
If you have any questions or concerns, feel free to contact us direct.
Raleclair
Oct 8, 2015 02:06 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
nomorecivicsi
Sep 10, 2015 03:58 PM
carid
Supporting Vendors
Sep 10, 2015 10:17 AM
Simran Mann
Sep 9, 2015 02:08 AM
