Vossen CV-3 X KW V3
Old Oct 29, 2012 | 01:58 AM
nigelktm's Avatar
nigelktm
Vossen CV-3 X KW V3
Hi guys!!
I have the CV-3 (+20/+25) with falken tires and the GREAT KW CV-3 coils. Just wondering if there is any members here that have the same setup and would like to share their damper setting, etc ? I am trying to find some daily driver setting.
PS please state your ride height too
Old Oct 29, 2012 | 11:00 AM
Seraphix's Avatar
Seraphix
All depends on how low you want to go. I had that set up at 25.5" fender to ground and was running 9 front and 11 rear. Ride was a little rough not jarring though. I raised the rears to 25 7/8 and it rode better than stock. Most guys reverse those numbers 11 F and 9 rear, and the ride is excellent as well from what I read on here. I just didn't want to keep going back to the rears to adjust them. Good luck bud
Old Oct 29, 2012 | 11:11 AM
ECain18's Avatar
ECain18
yes i rode with 11 front and 9 rear and it rode much better than stock. Stiffer but much smoother and tighter if that makes sense.
Old Oct 29, 2012 | 11:12 AM
ECain18's Avatar
ECain18
edit: just saw you have cv3's. They are 20" wheels and heavy as well so your ride would probably be rougher than mine due to the wheels. You might want to go slightly lower on your settings. Each click makes a big difference. you might want to do 10 front/8 rear or 9 rear
Old Oct 30, 2012 | 10:39 AM
nigelktm's Avatar
nigelktm
Thanks guys!! No wonder why I feel so damn hard, my mechanic did 12F/10R. What is the compression phase adjustment for your car?
Old Nov 1, 2012 | 09:15 AM
jarvo's Avatar
jarvo
Smooth and tight.
All night.
Dillybar12
Nov 1, 2015 07:23 PM
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
John B
Sep 27, 2015 11:41 PM
kinchi
Sep 25, 2015 12:04 AM
