help with wheel offset and suspension
Old May 3, 2012 | 04:21 PM
axelamoe's Avatar
axelamoe
A local guy is selling his wheel off of a hyundai genisis they are Stance SC-5ive Front 20x9 +20 Rear 20x10.5 +27. What do you guys think? i have no clue about offset and stuff like that. I am dropped on KW v1 and have the rear spc kit and toe. There is also custom made box in the trunk with two 10s to keep in consideration for weight. Will this setup work on my car? what do i need to do. I dont like the tucked in look or too much poke. I want to sit flush with not too much gap. Thanks moe
Old May 3, 2012 | 04:42 PM
joo030879's Avatar
joo030879
coupe or sedan?
Old May 3, 2012 | 04:50 PM
axelamoe's Avatar
axelamoe
coupe g37s sorry.
Old May 3, 2012 | 04:55 PM
joo030879's Avatar
joo030879
This is +35 on Tanabe Springs. IMO just right. Flush.
This is +22 on KW V3, very aggressive.
So yours should be right in the middle. Sorry could not find the exact offset pic.
Old May 4, 2012 | 04:28 AM
Presto's Avatar
Presto
The fronts should be fine. Fr the rear what size tires will you go with? 275 tires will need -2 or so camber n the rear.
Old May 4, 2012 | 06:32 AM
G37HKS's Avatar
G37HKS
Front is fine but rear is stick out much, for 10.5 rear, i woulnt go less than 32...
Old May 4, 2012 | 09:00 AM
Sunny G's Avatar
Sunny G
It can fit with a smaller tire e.g. 225/35/20 and 255/30/20 maybe even a 275/30/20. It all depends on personal preference
Old May 4, 2012 | 10:36 AM
WPPJR30's Avatar
WPPJR30
You will be fine. I actually like those offsets a lot for a G coupe. I have run a few different set-ups, among them A) 10.5" and 9.5" (+22) all around and B) 10.5" (+25) and 9.0" (+27). I don't like the car slammed or the stretched/poke fad, either. The offsets you are looking at are in the perfect range, in my opinion.
Old May 4, 2012 | 11:17 AM
axelamoe's Avatar
axelamoe
What tire sizes were you running? and did you have to do any more modifications? any rubbing issues? Thanks
Old Jun 24, 2012 | 03:24 PM
WPPJR30's Avatar
WPPJR30
I apologize. I don't know if it's too late, but I just saw this question... My rear bracket is trimmed. I have front and rear camber kits and the adjustability of coilovers. My ride is moderately dropped. I am nowhere close to "slammed" or "dumped."
One previous set-up
275/30/20 on 20"x10.0" (+35)
245/35/20 on 20"x9.0" (+25)
Another previous set-up:
275/35/19 on 19"x10.5" (+22)
255/40/19 on 19x9.5" (+22)
Current set-up:
285/30/20 on 20x10.5" (+25)
255/35/20 on 20x9.0" (+27)
*Tire selection was important here*
Old Aug 1, 2012 | 05:55 AM
swiney808's Avatar
swiney808
I have a 2012 g37S sedan with eibach pro kit springs and looking to purchase Stance SC5 wheels with 20x8.5 +35 front and 20x10 +35 rear with 245/35-20 and 275/30-20 tires. I was going to get Bridgestone RE760 sports but the guy at wheelstudio said it might scrape in the rear if I have people in the rear. He said they are wider then falkens which he recommended. I was hoping that I would not be scraping at all. Debating between the Hankook V12 and the RE760's. Any input would be appreciated.
Old Aug 1, 2012 | 09:23 AM
Kidcane's Avatar
Kidcane
Florida G Club
To the OP, perfect offsets IMO.
charneco
Feb 21, 2016 11:11 PM
TheLocNar
Dec 22, 2015 07:52 PM
helloandchau
Oct 6, 2015 05:26 PM
