Spring compressor needed?
Old Jan 7, 2012 | 02:09 PM
Fentress24's Avatar
Fentress24
When installing tanabe coils you reuse the stock upper mount in the front. Do you need a spring compressor when taking the upper mounts off the top of the stock spring? How much pressure is that spring under?
Old Jan 7, 2012 | 03:37 PM
fairladyz34's Avatar
fairladyz34
Yes, use a spring compressor for that. And be careful, compressed springs are under alot of pressure
Old Jan 7, 2012 | 04:09 PM
Tazicon's Avatar
Tazicon
Please be careful, to many horror stories out there when people use spring compressors and don't know what they are doing.
Old Jan 7, 2012 | 09:08 PM
Dieseldoug22's Avatar
Dieseldoug22
There is a thread about this. But you can take off the main bolt from the engine compartment before you remove the 3 nuts that hold the strut and use the car as the spring compressor. Then after you have the main bolt off jack up the body of the car and the strut and spring will come apart. Remove wheel and all other bolts to remove strut and when you reinstall the new springs they are shorter so you won't have to worry about compressing it. If needed you can even put a block under the lower arm and lower the body to compress the spring and reinsert the strut into the top plate.
Thread about it. Start around the 18th post.
Old Jan 8, 2012 | 11:51 AM
Fentress24's Avatar
Fentress24
thanks guys. ended up running to advanced auto parts and just renting a spring compressor. I think everything turned out really well. I am very impressed with the ride of the Tanabe coils. I only have experience with springs on my previous cars. Coils are a big ride improvement.
Old Jan 8, 2012 | 12:16 PM
fairladyz34
Yeah man! That looks great, nice low drop!
G's
Nov 5, 2023 12:01 PM
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
Mattlorentzoe
Aug 21, 2015 03:54 PM
Upser88
Aug 20, 2015 08:30 AM
