Stock Brakes and Big Brake Kits weight
Old 01-02-2012, 09:09 AM
ECain18
ECain18's Avatar
For those checking on rotor and brake kit options, here are some weights for popular choices. Don't sue me if anything is wrong, I only found this from 350z tech and thought it might help anyone trying to decide:
Stock Akebono (Sport Brakes 370z):
Size:
Front caliper: 4-pot
Rear caliper: 2-pot
Front rotor: 355mm
Rear rotor: 332mm
Weight:
Front caliper: 11lbs
Rear caliper: 6lbs
Front rotor: 29lbs (1-piece)
Front DBA rotor: 22lbs (2-piece)
Front Rentless Autosport rotor: 19lbs (2-piece)
Rear rotor: 21lbs
Stoptech 355mm front rotor: 19lbs (2-piece)
Stoptech 380mm front rotor: 21lbs (2-piece)
(need to confirm these fit and what weight of stoptech 1-piece rotors are)
AP Racing:
Size:
Front caliper: 6-pot/4-pot
Rear caliper: 4-pot/2-pot
Front rotor: 363mm/332mm
Rear rotor: 332mm
Weight:
Front Caliper (6-pot): 7.3 lbs
Rear caliper (4-pot): 4.7 lbs
Front Rotor: 20.3 lbs
Rear Rotor: 22.8 lbs
Stoptech:
Size:
Front Caliper: 6-pot (ST-60)/4-pot (ST-40 or ST-45 with 380mm rotors)
Rear Caliper: 4-pot (ST40)/2-pot (ST-22)
Parking Brake: 1-pot (ST-10)
Front rotor: 380mm/355mm/332mm
Rear rotor: 355mm/332mm
Weight:
Front Caliper (6-pot): 8.5lbs
Rear Caliper (4-pot): 7.94lbs
Front 380mm: 21lbs
Rear 355mm: 19lbs
Front Caliper (4-pot): 7.94lbs
Rear Caliper (2-pot): 4.4lbs
Front 355mm: 18lbs
Rear 332mm: 15lbs
Parking Brake: 4.13lbs
Alliance:
Size:
Front caliper: 8-pot/6-pot
Rear caliper: 6-pot/4-pot
Rear rotor: 355mm/322mm
Weight:
Front Caliper (8-pot): 6.50lbs
Rear Caliper (6-pot): 5.95lbs
Front 380mm: 21.00lbs
Rear 355mm: 21.75lbs
1996 TT #61 of 300
Old 03-01-2012, 03:54 PM
TeeItHi
TeeItHi's Avatar
1 ir 2 piece rotors?
Stoptech:
Size:
Weight:
Front 380mm: 21lbs
Rear 355mm: 19lbs
Front 355mm: 18lbs
Rear 332mm: 15lbs
are the stoptech 332mm 15lbs rear rotors 1 or 2 piece? and i'm assuming this are ok for straight swap to fit with stock rear caliper?
thanks
also, just wanna tell you that you're doing great job with all this loosing weight thing. the car.
Old 03-01-2012, 11:03 PM
Kuro
Kuro's Avatar
Great info Eric
Old 03-02-2012, 03:13 PM
ECain18
ECain18's Avatar
@teeithi: they are the 2 piece rotor option in stoptech's BBK. NOT the 1 piece powerslot rotors. Those weigh in around the stock 23 lbs
Old 03-02-2012, 03:14 PM
ECain18
ECain18's Avatar
thanks buddy i looked forever for something like this when I was trying to decide on my AP racing bbk vs. stoptechs. One thing I like about AP racing is the lightweight and no rust ring. The stoptech BBK still get the same rust ring I had on my powerslot rotors from the pictures I saw
Old 03-03-2012, 02:27 AM
Kuro
Kuro's Avatar
Yeah that I've heard and seen on stoptech rotors :/
Old 06-02-2012, 08:02 PM
advan37
advan37's Avatar
Thanks for info !
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
WolfSongX
Car Care & Detailing
05-10-2017 07:26 PM
gcruzjr78
08-18-2015 10:15 AM
TheLocNar
08-16-2015 07:14 PM
Ihtbealexxx
08-09-2015 03:30 AM
Quick Reply: Stock Brakes and Big Brake Kits weight
