Help New Car tires sizes
Old Dec 4, 2011 | 03:42 AM
masterdukill's Avatar
masterdukill
I got Yokohama AVID Envigors 245/45R/18 all around. Damn its so much better than the stock dumloops.
Old Dec 4, 2011 | 10:15 PM
kcg37's Avatar
kcg37
Can you post a pic of front wheel? Curious as to what a 245 looks like on 7.5 in. Wheel. Thanks in advance.
Old Dec 9, 2011 | 03:51 AM
masterdukill
I'll get a pic this weekend, and the stock oem 18" are 8in wheels.
Old Jan 5, 2012 | 01:12 AM
masterdukill
new tires :D
totally forgot to post, here are the yoko 245/45/18 envigors
They are not noticeably bigger when looking at the side, but looking from behind is another story I should of taken before/after pictures.
Grip quality is absolutely better in every way compared to the lame oem dunloops. No more slips, and i have 999% better grip on wet pavement. And traction control rarely shows up anymore. Not afraid to go past the 2K rpm line on wet pavement anymore (still stay under 4K lol)
Attached Thumbnails New Car tires sizes-img_4588.jpg   New Car tires sizes-img_4591.jpg   New Car tires sizes-img_4610.jpg   New Car tires sizes-img_4612.jpg   New Car tires sizes-img_4613.jpg
Old Jan 5, 2012 | 09:48 AM
Ron's Avatar
Ron
How does the steering input feels with bigger tires? Are you planning on lowering since 45 series will show more fender?
Thanks,
Ron
Old Jan 6, 2012 | 02:28 PM
Ron's Avatar
Ron
Thinking about running the same tire ratio but with the 970AS
Ron
Old Jan 7, 2012 | 04:18 AM
masterdukill
Steering feels a little heavier at first, but that seems to always happen when I get new tires. After 2 weeks, it seems normal now, which is very grippy. No intention on lowering yet, don't really notice a difference in height on fender. Its suppose to be only a 4mm difference in total diameter, I think that's hardly noticeable. I plan on getting the most out of my current suspension, and avoiding driveway scraps for now. Once my current suspension gives out(probably never huh?), I plan on moving to coilovers, or w/e is best at the time
Old Jan 7, 2012 | 04:22 AM
masterdukill
Oh, a PSI question, when i got the new tires, they filled it to 40PSI, is that right?? Car specs says suppose to be 34psi. I lowered it back down to 35PSI, trying to get the center to wear more since the inside is suppose to wear more. Took it out to dealership for only oil change the next week, and they bumped it up to 38psi when i checked. These are all cold readings. What is the correct PSI???
Old Jan 7, 2012 | 12:31 PM
Ron's Avatar
Ron
Do you have any pictures showing the whole car with your new tire set-up? They look awesome though...
Ron
Old Jan 7, 2012 | 08:27 PM
masterdukill
Don't have any pics of whole car, should of done it when i washed it. It'll be a while before i wash it again for another pic I might forget by than. Its nothing special, just looks like a normal stock blue slate g37 coupe with a shinier stillen exhausts
Old Jan 7, 2012 | 11:59 PM
Ron's Avatar
Ron
I have the stock Dunlops with only 14,000 miles which are terrible and they're coming off this summer for a pair of BS RE760AS.
Wig
Old Jan 8, 2012 | 11:14 PM
earthmaster's Avatar
earthmaster
So um well 245/45/19s all around work for the coupe? Since stock is 225 and 245 right? i'm thinking about putting the same all seasons around.
Old Jan 9, 2012 | 11:52 AM
Ron's Avatar
Ron
Did you find out the proper tire PSI for both front and back?
Thanks,
Ron
Old Jan 10, 2012 | 03:49 AM
  #29
masterdukill
earthmaster, not these were 225/50/18 stock all around upgrade to 245/45/18. The 19" rim have different widths in front and back, don't think you should do the same thing.
Ron, nope. I'm just sticking with 35PSI. Ideally, you should be going by the car specs, which is 34psi. I believe PSI on a tire spec shouldn't change with different widths because the load psi is still the same. I pump 1 or 2 psi more, b/c there is a stock negative camber that causes more wear on the inside of the tires. I'm only hoping to offset this inner wear by putting more wear in the center.
RE760AS are a good choice , but too overkill for me For the price, and purpose, I went with Yokos Avids W4S. Not as good for icy roads, but i don't drive on icy roads . They are just as good as the re760as on dry/wet conditions, so i thought that's the best bang for buck quality.
Old Jan 10, 2012 | 09:59 AM
  #30
Ron's Avatar
Ron
Thanks!
Ron
Mattlorentzoe
May 24, 2021 08:49 PM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
jayrdong
Oct 25, 2015 10:00 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
