8 pot front 2 back?
8 pot front 2 back?
I'm seriously considering the ksport 8 pot front brake kits (13"). Now I don't want this to become a "bigger isn't better" discussion. I just want to know if running 8 pot in the front and the akebono 2 pot in thy back works?
I know but ksport price is just too good to consider a different kit. The 8 pot is the same size and the ap 6 pot. The just shrunk the pistons a bit and added two more. So 2 in the back with technically 6 in the front would work okay?
Don't u need new wheels for 8pod to fit? U have the 18" right? 8pod will be pointless if u don't upgrade ur tires too, 225s won't do. 8front 2rear will also cause u more understeering, which u alrdy do w/ awd.
^^ why's that? An I will be upgrading my (summer) tires anyways. That's not an issue. Why will this setup cause not understeer? I assume only under braking you mean?
