are my front & rear camber settings ok?
Old May 17, 2011 | 02:48 PM
TeeItHi's Avatar
TeeItHi
i've got f245/35 19 & r275/30 19 on stock wheels after alignment result
front left camber - initial -1.5* min -1.2* max 0.3* final -1.5*
front right camber - initial -1.9* min -1.2* max 0.3* final -1.8*
rear left camber - initial -1.8* min -1.8* max -0.8* final -1.7*
rear right camber - initial -2.6* min -1.8* max -0.8* final -2.1*
rear left toe - initial 0.10* min 0.00* - max 0.11* final 0.05*
rear right toe - initial 0.18* min 0.00* - max 0.11* final 0.05*
they recomend i get a camber or alignment kit for the rear but none on the front.
ANY SUGGESTION?
thanks
Old May 17, 2011 | 02:51 PM
That's not your front camber, it's caster. Please post a scan of your sheet.
Old May 17, 2011 | 02:54 PM
Doggy's Avatar
Doggy
What are you dropped on?
Old May 17, 2011 | 03:11 PM
TeeItHi's Avatar
TeeItHi
Ooops!
correction made on caster/camber. sorry can't scan at the moment.
I have eiback pro kit.
Old May 17, 2011 | 03:14 PM
Doggy's Avatar
Doggy
Your camber doesnt seem bad to me, id leave it at is
Old May 17, 2011 | 03:27 PM
TeeItHi's Avatar
TeeItHi
just a little concern
i'm just a little concern cuz the stock 19" size snows had excessive wear in the inside of rear tires.
Old May 17, 2011 | 03:44 PM
You may have the excessive wear due to excessive toe. That's why it's important for people to be able to see the actual alignment spec sheet to get the whole picture in order to help you out. Next time when requesting help, try to post the sheet first.
Old May 17, 2011 | 04:07 PM
TeeItHi's Avatar
TeeItHi
rear toe added.
Old May 17, 2011 | 04:10 PM
Doggy's Avatar
Doggy
You're fine, as BB said it's the toe that eats tires quick
Old May 18, 2011 | 02:19 PM
TeeItHi's Avatar
TeeItHi
Camber?
What do you think of my camber in front & rear? Are they a little more than normal? Or is this also preference on how they look?
Old May 18, 2011 | 06:36 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
your camber looks fine. Where did you take it???? They should atleast be able to pull your toe back into spec so there's no pull. This will prevent the majority of any uneven tirewear. Otherwise with your camber specs you should be fine.
Some people prefer to get under -1 for camber for the "look", but for performance wise you're just fine running around -2 camber with maybe VERY minimul uneven tirewear.
Troop12
May 9, 2018 02:40 PM
Jensen Mathew
Aug 16, 2015 08:06 PM
Redfire32
Aug 11, 2015 09:05 AM
stpncaV37
Aug 10, 2015 08:05 PM
