Help Deviating from OEM tire size
Old Mar 29, 2011 | 12:45 AM
eksigned's Avatar
eksigned
Has anyone by chance deviated away from the OE tire size on stock wheels? I went from 225/50/18's to 225/45/18's. Unfortunately I didn't realize how much difference there was, after the fact, in sidewall length - less than an inch, just about ~.7 inches smaller in sidewall length. I'm assuming this is a safe bet, but can someone confirm? ABS issues? I unfortunately kept the rears the same OE size. My plan was to reduce the sidewall amount a bit in the front and then drop the sucker...
Old Mar 29, 2011 | 11:43 AM
FatBoyG37S's Avatar
FatBoyG37S
You will be fine...I also have a 2010 sedan. You should get a 245 for the front...it will fit.
Old Mar 29, 2011 | 05:01 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Would be an inch shorter than the oe size. They make load but will throw the speedo off a little. Better size would be a 245/45-18.
Mattlorentzoe
May 24, 2021 08:49 PM
jayrdong
Oct 25, 2015 10:00 PM
connoisseurr
Sep 20, 2015 04:14 PM
Hiryuu
Aug 7, 2015 07:08 PM
Rubyq60
Aug 3, 2015 10:36 PM
