Works vs-xx on g37s coupe
Old Mar 28, 2011 | 11:00 AM
snapO's Avatar
snapO
Hi, I was wondering what offsets I need for the front and rear on these rims. 19" 9.5f and 10.5r and what tire size for a semi aggressive look.
Old Mar 28, 2011 | 12:05 PM
Loi's Avatar
Loi
+24 front +35 rear , with 245 front and 275 rear tire.
Old Mar 28, 2011 | 12:11 PM
snapO's Avatar
snapO
cool, thanks. will i need cambers for both front and rear or just rear?
Old Mar 28, 2011 | 12:31 PM
ReddieG37's Avatar
ReddieG37
This depends on how low you're going to drop the car.
Old Mar 28, 2011 | 12:38 PM
Loi's Avatar
Loi
Yea, with those offsets and tire set up, you'll be on the border of hellaflush and flush so, you'd want a nice drop, but not too low. front and rear camber kits are recommend along with the coilovers.
Old Mar 28, 2011 | 01:51 PM
Doggy's Avatar
Doggy
Depends what look your going for, You can run +20 front + 25 rear and maybe stretch the tires a little.
Old Mar 28, 2011 | 02:07 PM
Loi's Avatar
Loi
I believe you are referring to +20 on a 9" Vossen rim. A +20 on a 9.5 rim is different.
Old Mar 30, 2011 | 10:51 AM
myk1013's Avatar
myk1013
I have +35 on my 9.5" in the front.... It's a little sunken, a 10-15mm spacer should make it flush.
So a +15 to +20mm offset on a 9.5" wheel would sit flush or hellaflush.
Old Mar 30, 2011 | 02:42 PM
MyocyteX's Avatar
MyocyteX
Thanks OP: I was wanting to ask this same question. Are you looking qt 19's with step lip?
Would this set up require spacers to clear the akebonos?
Old Mar 30, 2011 | 02:50 PM
jnguyen's Avatar
jnguyen
It depends on the drop to make it semi aggressive. 19x9.5 +20 and 19x10.5 +25 is bordeline flush without having to drop super low. Maybe just above the tire to hide fender gap. Also require little to no camber. Rear would need maybe just 2.0 and front would require none.
Old Mar 30, 2011 | 03:15 PM
cdeez's Avatar
cdeez
this right here...
Old Mar 31, 2011 | 11:29 PM
ARMANDITO's Avatar
ARMANDITO
What offsets on Vossen wheels Model vvs-cv1 on 20x9 and 20x10 1/2, I'm looking to get the tire flush to the fender, I will drop the car later on with coil overs, but just enough to bring the fender to the tire. By the way, what coilovers do you reccommend me that is not too hard, just with a nice quality ride. Thanks
Old Apr 1, 2011 | 12:07 AM
snapO's Avatar
snapO
im on S techs. i ordered the gt-30s. 20" 9.5 +34F and 10.5 +23 rear. said i should sit pretty flush without the need of spacers. i'll post pics after i mount em with tires.
Old Apr 1, 2011 | 12:10 AM
STOOF's Avatar
STOOF
+34 and +23...sorry but you wont be flush.
Old Apr 1, 2011 | 12:34 AM
Loi's Avatar
Loi
+1
Did you even bother reading the replies before picking those offsets?
