How do you get your tanabe coils EVEN???
Old Jan 4, 2011 | 03:18 PM
911turbo's Avatar
911turbo
been messing with the tanabe coils for a while. alrready got it aligned...
Now it just annoys the hell out of me because my driver side is a tad higher than my passenger!
How do you adjust your coils to know your sitting EVEN?
Post your methods of adjustment please!
Old Jan 4, 2011 | 04:20 PM
rAiN's Avatar
rAiN
shouldve measured it when the coils were off from the car.
Old Jan 4, 2011 | 04:26 PM
Kidcane's Avatar
Kidcane
Florida G Club
LOL I used a tool called a ruler. Then when I made adjustments I counted the number of turns I did and then did the same number on the other side. You may want to consider leaving the driver side a little higher because usually it will settle a little more on that due to the weight being on that side most of the time.
Old Jan 4, 2011 | 04:28 PM
DmfG37sTT's Avatar
DmfG37sTT
^^rofl. Go with KW coils, they are way better
Old Jan 4, 2011 | 06:26 PM
Once they've settled, measure each corner accurately. Then adjust up or down where needed. One complete turn of the collar is 2 mm.
Old Jan 6, 2011 | 12:28 AM
voltic's Avatar
voltic
Remove the elephant from your passenger seat.
Old Jan 6, 2011 | 12:43 AM
TomieG's Avatar
TomieG
I have the same issue as well...
My guess is to measure from the ground up to the fender on a level surface.
Old Jan 6, 2011 | 01:22 PM
G_rev's Avatar
G_rev
Take the one of the lock rings... if you want it any lower.
And measuring wise.. I suggest measuring somewhere beside your fender. At many times if you've been in an accident or you modified it somehow the fender won't be leveled. I would measure somewhere solid... like the crossmember and etc...
are your tire pressure both the same on each side?
Old Jan 7, 2011 | 07:08 PM
InspiredMan's Avatar
InspiredMan
yes, because KW's coilovers will install even right out of the box...
OP,
you measured before turning? Your turns aren't going to be exact on each corner so just measure much threaded area there is after you have your desired hieght on a side and match that length on the other.
Old Jan 13, 2011 | 12:14 AM
G4FSR's Avatar
G4FSR
Is the 2 mm for both front and rear. Just curious coz the rear diameter is bigger.
Old Jan 13, 2011 | 12:34 AM
joo030879's Avatar
joo030879
I do the primitive way. I count the rings. KW's have nice evenly spaced so it was not so hard. I don't know about Tanabe, didn't like their springs either.
Rick in NC
Intake and Exhaust
27
Jan 6, 2019 09:47 PM
Murkr
Sep 28, 2015 10:45 AM
m3clubracer
13
Sep 28, 2015 09:54 AM
killingforpeace
Sep 27, 2015 05:50 PM
VQCrew
Sep 26, 2015 01:19 PM
