Stock Bridgestones with 33k miles
Cause my front wont go into spec. There isn't any adjustment on the front. Rear is fine. Front caster and toe are fine. Front camber is not. If I remember ill post my alignment sheet from before and after.
Found my alignment sheet. Here are the specs before and after:
Before:
LF camber- -1.2*
LF caster- 4.8*
LF toe- -3/32in
RF camber- -1.7*
RF caster- 5.1*
RF toe- 3/32in
Total Toe- -1/32in
Steer Ahead- -0.18*
LR camber- -2.1*
LR toe- 3/32in
RR camber- -2.1*
RR toe- 0in
Total Toe- 3/32in
Thrust Angle- 0.09*
After:
LF camber- -1.2*
LF caster- 4.7*
LF toe- 1/32in
RF camber- -1.7*
RF caster- 5.1*
RF toe- 1/32in
Total Toe- 1/16in
Steer Ahead- -0.01*
LR camber- -1.6*
LR toe- 3/32in
RR camber- -1.6*
RR toe- 1/32in
Total Toe- 1/8in
Thrust Angle- 0.05*
I'll get before and after with the SPC arms.
Before:
LF camber- -1.2*
LF caster- 4.8*
LF toe- -3/32in
RF camber- -1.7*
RF caster- 5.1*
RF toe- 3/32in
Total Toe- -1/32in
Steer Ahead- -0.18*
LR camber- -2.1*
LR toe- 3/32in
RR camber- -2.1*
RR toe- 0in
Total Toe- 3/32in
Thrust Angle- 0.09*
After:
LF camber- -1.2*
LF caster- 4.7*
LF toe- 1/32in
RF camber- -1.7*
RF caster- 5.1*
RF toe- 1/32in
Total Toe- 1/16in
Steer Ahead- -0.01*
LR camber- -1.6*
LR toe- 3/32in
RR camber- -1.6*
RR toe- 1/32in
Total Toe- 1/8in
Thrust Angle- 0.05*
JoshB
Oct 15, 2015 03:08 PM
drewfinity
Aug 20, 2015 08:17 PM
