Help Will the OEM Akebono BBK Fit?
Old Nov 4, 2010 | 04:43 PM
tradical1's Avatar
tradical1
I have a G37x coupe, and am wondering if the OEM BBK will fit with my stock 18" wheels. I am quite certain that the diameter will be fine. However, I'm not sure about the offset.
I know there has been a lot of talk related to this, but I can't find anything specific to the G37x, only with respect to the RWD models. I have heard that the offset of the overall wheel position is different in the x because of the different wheel hub.
Do I need a spacer in order to use these brakes?
Old Nov 4, 2010 | 08:35 PM
Elco's Avatar
Elco
No. the OEM sport brakes dont fit with the stock 18' wheels.
I just tested that on my vert.
I am planing to get sport brakes for my x sedan and i whanted to know if they will fit.
So i toke one wheel off the sedan and try to puth it on my G37 convertible.
The wheel spikes rub the brakes caliper.
With some concave wheels (different offset) will be OK.
Old Nov 5, 2010 | 12:40 AM
tradical1's Avatar
tradical1
So, it looks like I need spacers. What do I need?
Old Nov 5, 2010 | 01:02 AM
Fezzik's Avatar
Fezzik
Was this on the front or rear you tried this?
Old Nov 5, 2010 | 01:11 AM
STOOF's Avatar
STOOF
Def doesnt fit without spacers.
Not sure how big of a spacer is needed though.
Old Nov 5, 2010 | 01:29 AM
tradical1's Avatar
tradical1
5mm spacers is about as far as you can go without replacing the studs. Do I need new studs in order to upgrade my current setup?
Old Nov 5, 2010 | 02:00 PM
DJ Hellfire's Avatar
DJ Hellfire
Just get some 20 or 25mm spacers all around. Even without the brakes in the picture, the spacers alone will make the car sit better. Don't worry about changing studs. Just get hubcentric spacers with the studs built in!
Old Nov 7, 2010 | 10:45 AM
tradical1's Avatar
tradical1
I'll admit, I've never even looked at using spacers before, but 20mm sounds a bit extreme to me. How much will that affect the steering and overall feel of the car through the twisties?
Old Nov 9, 2010 | 11:04 AM
tradical1's Avatar
tradical1
So, it looks like putting the Akebono OEM BBK on my car is going to be a hassle. What about the Brembo kit from the G35/370Z? They're a little smaller, so replacing the pads/rotors should be cheaper. Also, I'm hoping that they won't require such massive spacers. Has anyone upgraded their G37 to the Brembo BBK from the V35?
Old Nov 9, 2010 | 11:27 AM
da mayor's Avatar
da mayor
ill be putting spacers on tomorrow on my g37x coupe... 20mm isn't extreme. personally i felt a small difference with braking since it has a little more air inbetween the rim and brake caliper on my sedan
ichiba v2 spacers bolt right onto the OEM wheel studs
after spacers
before spacers
04G35NYC
May 2, 2016 05:15 PM
johnadlertech
Sep 14, 2015 12:18 PM
KAHBOOM
Aug 25, 2015 11:05 AM
RoyalG37
Aug 11, 2015 12:21 PM
Ihtbealexxx
Aug 9, 2015 03:30 AM
