20" xxr 521 fit 10' Sport Sedan?
Old Oct 22, 2010 | 02:01 AM
zakattak20's Avatar
zakattak20
Hello all,
Was wondering if the xxr 521 wheels could any way fit the 2010 g37 sport sedan? Don't mind fender rolling, going to be lowered on eibach springs.
20x8.5 +32 front
20x10.5 +30 rear
Thanks for your help
Old Oct 22, 2010 | 04:26 PM
black_sedan's Avatar
black_sedan
I think whats more important to know, is tire size.... If you're planning on running a 275/30 its going to take alot more than running a stretched tire setup with that offset/width.
Old Oct 22, 2010 | 04:44 PM
da mayor's Avatar
da mayor
yes it will fit
Old Oct 23, 2010 | 01:27 AM
zakattak20's Avatar
zakattak20
by needing more do you mean rolling the fenders?
Da Mayor, have you had experiences with this type of setup?
Thanks
Old Oct 23, 2010 | 09:37 AM
EnviedG35's Avatar
EnviedG35
ON eibachs, the front will fit with more than enough room....im running a +20 8.5 up front and i could probably push it out another 5mm or so. The rear, will be rather aggressive, even with the drop. You will need to run at least a 255 tire and some decent camber ( more than -1.7 )on the rear to get it to clear the fender. ALso, the 2nd gen sedans fenders are already flat on the inside, there is nothing that can be rolled.
Here is my 10" +35 rear. As you can see the wheel is already slightly past the fender. A 10.5 +30 will put your wheel about another .75" past the fender, so you will need a good size stretch to get it to clear.
Old Oct 23, 2010 | 10:14 AM
da mayor's Avatar
da mayor
I have 20x8.5" fronts 40mm offset and a 25mm spacer on..(est. 15mm offset then)
. the rear is 20x10" rim 40mm offset with 15mm spacers... (est. 25mm offset then)
I have 245/30/20 tires front and rear.
Old Oct 23, 2010 | 11:06 PM
zakattak20's Avatar
zakattak20
thanks to all of you, so with a 255 stretched tire in the rear should be something I would go with?
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
i heart ricers
12
Dec 9, 2015 04:15 AM
drive6MT
Sep 14, 2015 12:36 PM
zero260
Aug 12, 2015 10:02 AM
cabo
Aug 9, 2015 03:25 PM
