Help tires
Old May 6, 2010 | 08:56 AM
novaleadfoot's Avatar
novaleadfoot
tires
new g37 awd...stock rims...stock eagle rs-a tires (225-55-17)
ok, so the eagles are not even close to being the tire this car needs
seems choices for a uhp a/s or reasonably priced summer tire are limited in the 225-55-17 size
what size tire (on the oem rim) can I go to that won't affect the speedometer or change the overall circumference by much...looking to get more choices in tires on tirerack
thanks for your help
Old May 6, 2010 | 09:36 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
if you are keeping the OEM wheels then just keep the aspect ratio the same as the OEM tires and it doesn't matter what width you get (so if you get wider tires, get a lower aspect ratio).
even bigger wheels won't affect the speedometer as long as the aspect ratio is taken into consideration with the tires
Old May 6, 2010 | 09:42 AM
novaleadfoot
yes, said much better than I said it...now, how do I know what size to go to and keep the same aspect ratio?
thanks
Old May 6, 2010 | 11:41 AM
freesurfer's Avatar
freesurfer
Here are the three sizes you can use. Tire rack doesn't have any sizes for your 17's in the 40 series or 60 series that wouldn't throw off your speedometer.
225-55-17
245-50-17
275-45-17
For the price of 4 new 17" tires, you could buy some members used OEM 18" wheel and tire package, that's what I'd recommend.
Old May 7, 2010 | 05:39 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
Many use a 245/50-17, but you have a much better tire selection in the stock 225's.
Old May 9, 2010 | 10:56 PM
novaleadfoot
Originally Posted by Neal@tirerack
Many use a 245/50-17, but you have a much better tire selection in the stock 235's.
thanks Neal and for the other responses
so 245-50-17 is safe to use for spirited driving?
225-55-17 has the new Goodyear Eagle UHP A/S and 245-50-17 has the Conti DWS...I think the DWS is on backorder, though...spoke to Continental and they said the supply just cant keep up with the demand for the DWS
225-55-17 also has the new Pirelli PZero Nero All-Season
beyond these choices (excluding a pure summer tire), I don't know anything else worth considering in the hp a/s or uhp a/s range...any other suggestions? between the Eagle and the Pirelli, which has the best overall performance? and what about long-term wear?
Old May 10, 2010 | 10:25 AM
Neal@tirerack
Thanks for calling in
Old May 10, 2010 | 12:49 PM
novaleadfoot
np...thanks for the advice...will call soon with decision
B Feelgood
Sep 1, 2020 02:50 PM
RYs06MT
Apr 22, 2016 11:00 AM
bri
Nov 23, 2015 11:35 PM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
