Help Need offsets help!!
Jan 19, 2010 | 07:45 PM
Need offsets help!!
Im planning on getting Lexani wheels F:20x8.5, R:20x10... with 285 tire in the rear. Im also gonna lower it with Eibach pro-kit.... What offsets should i be running so I dont rub?? I have the G37S btw
Jan 19, 2010 | 09:16 PM
Somewhere in the 30s should be ok
Jan 19, 2010 | 09:19 PM
yeah, around +35ish or higher. i have +27 with 275; when i rub, it sounds like the tires is about to blow.
Jan 20, 2010 | 10:06 AM
So +35 for the fronts too?
Jan 20, 2010 | 10:09 AM
Actually on the fronts you can go all the way down to mid or high twenties. Rears mid thrities.
Jan 20, 2010 | 07:52 PM
True, I did 20mm spacers all around and the fronts looked like they could use even more for a perfect flush, so you could use lower offsets in the front than in the rear
Jan 22, 2010 | 06:01 PM
I called and they said the offset were +35(F) and +38(R).... how do you guys think it will look?
Jan 22, 2010 | 08:43 PM
Jan 22, 2010 | 10:32 PM
20x8.5 +35 offset may not fit. i suggest you should get at least +25 on 8.5 wheel
you should get +32 on 10 inch wheel for the rear
Jan 23, 2010 | 12:25 PM
What do you mean "may not fit"?
Jan 23, 2010 | 04:38 PM
G37SAM: What offsets are you running on your wheels?
Jan 23, 2010 | 04:49 PM
I'm on stock wheels Ozzy, I just have 20mm spacers all around
Jan 24, 2010 | 01:02 PM
What would be another "ideal" offset besides +35(F) and +38(R).... for what im looking for?
Jan 24, 2010 | 02:09 PM
Quote:
Originally Posted by
G37Sam
i recently tried on some wheels that are 8.5 with mid 30 offsets and they did not clear the S brakes. that's why i said they may not fit.
Jan 24, 2010 | 02:56 PM
Weiboy718
Which wheels did you try on?
