Help Brake Fluid for a BBK kit
Old Dec 7, 2009 | 04:32 PM
SOLISIMO's Avatar
SOLISIMO
Question Brake Fluid for a BBK kit
Im going with an 8 piston front and 6 piston rear BBK. What do you recommend for brake fluid. I dont track the car at all, never will I drive normal but still want some good stuff incase I need to use it
Old Dec 7, 2009 | 04:37 PM
jnguyen's Avatar
jnguyen
Talk to Mike he know his ****. I think generic or rbf600 is good if you don't track or anything.
Old Dec 7, 2009 | 04:48 PM
SOLISIMO's Avatar
SOLISIMO
Thats what I was thinking of Motul
Old Dec 7, 2009 | 04:54 PM
BOXER83's Avatar
BOXER83
What brake setup are you going with?
Old Dec 7, 2009 | 05:00 PM
I concur with the Motul RBF 600 recommendation.
Old Dec 7, 2009 | 05:10 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
I dont think you'd need RBF600 bro. Just regular old DOT3 or DOT4 would be enough. You're not doing any tracking and running some fancy shmancy brake fluid would really do you no good. In fact you might even have to change it more often.
Old Dec 7, 2009 | 05:21 PM
jnguyen's Avatar
jnguyen
Ditto of what gdizzle said.
Old Dec 7, 2009 | 06:23 PM
G37Sam's Avatar
G37Sam
To be honest, he don't even need 8 pot brakes to start with lol
Thinking about it, you slam on those 8 pot fronts and your stretched fronts might go kaboom..
Old Dec 7, 2009 | 06:32 PM
SilverBullet's Avatar
SilverBullet
Castrol SRF
Old Dec 7, 2009 | 07:59 PM
BOXER83's Avatar
BOXER83
If you slam on those you front end will hit the ground
Old Dec 8, 2009 | 06:32 AM
SOLISIMO's Avatar
SOLISIMO
especially the Hankooks since they are sooo sticky
hahaha Ill put little wheels on the bottom of the bumper
Old Dec 8, 2009 | 08:55 AM
BOXER83's Avatar
BOXER83
Yeah that might work, look a little crazy but.....LOL I drive my car very aggressive and take corners at high speeds so I don't need that much braking power but those brakes are nice.
Old Dec 8, 2009 | 09:08 AM
SOLISIMO's Avatar
SOLISIMO
shhhh not many people know
Old Dec 8, 2009 | 10:43 AM
soundmike's Avatar
soundmike
I concur with Gamedog. Any DOT3/4 fluid will work for a daily driver. If you want off-the-shelf stuff, Valvoline has great stuff -- i even use it for the occasional HPDE.
With your new set-up, i would venture to guess it probably comes with larger rotors and aluminum hats/calipers which may actually run cooler than your old Akebono set-up, so there's a little less risk of boiling your fluid.
You can use any fluid rated higher than that. Just keep in mind that higher performance fluid is even more hygroscopic than off-the-shelf stuff, so you may have to replace fluids more often.
Old Dec 8, 2009 | 10:48 AM
SOLISIMO's Avatar
SOLISIMO
So its just better to go with the stock infiniti stuff correct? Bc the dealer will be doing my install
