What Offset?
Old Aug 5, 2009 | 08:41 AM
BocaIvan's Avatar
BocaIvan
What Offset?
I have an 09 Sedan with Performance Tire and Wheel package. I believe the wheels are 18x7.5 all around with 225x50x18 tires.
I am planning on getting spacers for the front and the rear but do not know what the offset of the wheel is.
Does anyone have this information or recommend what size spacers I should get? I was thinking of getting 20mm all around.
TIA,
BocaIvan
Old Aug 5, 2009 | 10:59 AM
G37Sam's Avatar
G37Sam
Well I got 20mm on my coupe all around and it become perfect.. You can always drive down to a performance shop and have him try them on for you
Old Aug 5, 2009 | 05:56 PM
w0ady's Avatar
w0ady
measure the distance from the outside of your tire to the inside of your fender and leave a little space for suspension travel.
Old Aug 6, 2009 | 07:56 AM
BocaIvan's Avatar
BocaIvan
Ok so i found the info I needed about the offset. They are 45 all around.
So the question is, will 20mm fit flush and not go beyond the fenders or will I rub when the car is lowered on Eibach springs?
Thanks again!
Old Aug 6, 2009 | 08:04 AM
G37Sam's Avatar
G37Sam
depends on how far the fendor is from the wheels hub.. you'll have to check with folks with a G37 sedan and aftermarket wheels
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
