New wheels rubbing back caliper.
Old Jul 28, 2009 | 04:54 PM
Remo101's Avatar
Remo101
Just got new Lexani LSS-10 wheels mounted and the back wheels are rubbing on the top corner of the brake calipers.
The tech said they have seen this before and they just grid the calipers a bit, but that they wouldn't do that with my sport multi piston caplipers.
The offsets are G37 specific from Lexani this is Bull$h!t .
Has anyone else had this problem. If so what did you do.
Old Jul 28, 2009 | 05:05 PM
JKashat's Avatar
JKashat
Make them take them back. That's bs!
Old Jul 28, 2009 | 05:17 PM
TomieG's Avatar
TomieG
Spacers?
Old Jul 28, 2009 | 05:18 PM
STOOF's Avatar
STOOF
Make them take it back.
but if they give you a hard time just get a small spacer like 3 or 5 mm
Old Jul 28, 2009 | 06:21 PM
Remo101's Avatar
Remo101
So, I guess I'm one of the first to get the Lexani LSS-10s for the G37 with sport package. I was informed that Lexani told the vendors LSS-5s and LSS-10 would have the same caliper clearance. So the LSS-10 was machined to the same specs and the LSS-5.
Turns out the caliper clearance is not the same. I they sent me 3mm spacers and will work to get new wheels from Lexani for me.
I really don't want to run with spacers, but I guess it will be ok untill I get replacements.
I sucks though I really just want them on my ride.
Old Jul 28, 2009 | 07:48 PM
G37Sam's Avatar
G37Sam
Sorry to hear that, you can always sell them to non sports or on other forums if you hate spacers that much. What spacers are they sending you? Make sure they don't cause any vibrations
Old Jul 28, 2009 | 08:39 PM
ucla bruin's Avatar
ucla bruin
Tell them you paid for and agreed on paying for something that would clear the calipers. Not something that will clear the calipers with spacers. There was no mentioning of possible spacers. You find it unacceptable, and have received less of what you paid for. Complain to different sources, make it public, do whatever it takes for them to fix it for you.
Don't let them shoo you away with some spacers to fix the problem.
__________________
Old Jul 28, 2009 | 08:42 PM
STOOF's Avatar
STOOF
also if any damage was caused to your calipers, make them pay for it.
Old Jul 28, 2009 | 09:22 PM
Blackjack's Avatar
Blackjack
See if they will replace them with a better offset... If not, 3mm spacers should do it.
Old Jul 30, 2009 | 01:45 AM
TJHG37S's Avatar
TJHG37S
They should replace them for free, but just in case 3mm spacers won't be bad, I have them on my front iForged and no vibrating..
Old Jul 30, 2009 | 06:12 PM
w0ady's Avatar
w0ady
3mm spacers and problem solved. sucks they messed up but not a huge deal if you like the wheels. as long as the spacers are hubcentric, shouldnt be an issue.
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
james6980
Oct 9, 2015 01:28 PM
ddayeg37s
Aug 9, 2015 07:10 PM
Rubyq60
Aug 3, 2015 10:36 PM
