Spacer Problem...
Old Aug 4, 2009 | 02:24 PM
HamstersG's Avatar
HamstersG
^ Interesting and informative post.
Old Aug 19, 2009 | 09:54 AM
mishmosh's Avatar
mishmosh
If you have Ichiba V2 and have vibration, just do the fix linked by jran. I would not have believed it, but it worked like a charm on my sedan.
Old Aug 19, 2009 | 07:03 PM
AndrewDDS's Avatar
AndrewDDS
I am DYING to find the time to try this out now...
How hard was it for you guys to get the hubcentric ring out without removing the spacer?
Old Aug 19, 2009 | 07:06 PM
Kidcane's Avatar
Kidcane
Florida G Club
Good fix but a little ghettorific.
Old Aug 19, 2009 | 10:32 PM
HamstersG's Avatar
HamstersG
Mine came right out. But when I installed, I coated the backside of the spacer and the edge of the ring with very thin coat of high temp grease.
Old Aug 19, 2009 | 10:38 PM
HamstersG's Avatar
HamstersG
Being on the older side, I had to look up ghettoriffic to see if it was a compliment or an insult.
Old Aug 20, 2009 | 09:32 AM
Kidcane's Avatar
Kidcane
Florida G Club
Not really a compliment and not to be confused with ghettofabulous.
Old Aug 20, 2009 | 09:35 AM
GiGGaplease's Avatar
GiGGaplease
im so ghettofabulous. thanks kid.
Old Aug 20, 2009 | 03:53 PM
HamstersG's Avatar
HamstersG
"Jury-rigged, but terrific" so not a compliment and not an insult. I will just stick with old school simple words like that it was "informative and creative".
Old Aug 20, 2009 | 07:21 PM
BocaIvan's Avatar
BocaIvan
So is this a problem with the Ichiba spacers and a certain OEM wheel or is it with all the OEM wheels. I'm getting ready to pull the trigger on 2 sets...
Old Aug 21, 2009 | 07:03 PM
jran76's Avatar
jran76
3 came out with an easy tug, and one was a PITA (lots of wiggling).
Old Aug 21, 2009 | 08:16 PM
mishmosh's Avatar
mishmosh
Mine came out relatively easily. I had vibration with both aftermarket and OEM wheels with the Ichiba V2. I think the hubcentric ring just does not protrude enough. With the fix, no more vibration! There is also no need to keep replacing the wire--it still serves it's purpose of sticking the ring out a mm even after multiple takeoffs.
Old Aug 22, 2009 | 12:28 AM
AndrewDDS's Avatar
AndrewDDS
Finally got around to trying this today. My local Home Depot didn't have #10 copper wire, so I went with two turns of 16 gauge. I only did the fronts, and amazingly it worked like a charm!!
However, it was a complete biatch to get the rings out. I had to use WD-40 and let it sit for a few minutes before I could wiggle those suckers out, and the pliers kind of butchered the rings. I even had to file off some of the corrosion from the inside of the wheel hub before the rings would sit flush. In the end, this was the solution to my vibration problem! Thanks!!!
Old Aug 24, 2009 | 12:05 AM
  #29
HamstersG's Avatar
HamstersG
Yesterday I trimmed the rear wheel liner and bumper bracket and put the DIY #10 crush ring in the rear wheels. Took it down the road and not much change, but I only had a little bit starting at 50-70 mph. I was getting tired of it and about ready to take them off altogether, but like the look.
Today, put the #10 crush rings in the front wheels. Also, I tightened and torgued all the wheels in cross-pattern before setting the car down off the jack. Normally I tighten before lowering, but decided to torque them as well to make sure the crush ring was seating as evenly as possible.
Took it down the road.....could not believe it....smooth as glass.
I too had a little corrosion but not too bad. My rings came out real easy since I had greased the contact areas with high temp grease. Greased them up a bit again including where the wheel contacts the spacer.
Old Aug 24, 2009 | 01:26 AM
  #30
TomieG's Avatar
TomieG
Im about to have some spacers installed this week. Do you think i should bring some copper wire to the shop? Theyll prob look at me funny...
