Ok so im having my car dropped on Eibach pro kit springs next week
Old Jun 24, 2009 | 09:47 PM
TicketProof's Avatar
TicketProof
id like to push the wheels out a bit so they dont look so tucked once the car is lowered, i dont however want to do anything too aggressive where i risk rubbing or camber problems, etc. What size spacers front and back would people recommend ? thanks
Old Jun 24, 2009 | 09:49 PM
Kidcane's Avatar
Kidcane
Florida G Club
You are going to get a lot of different opinions but I say 10mm in the front and 15mm in the rear or 15mm all the way around.
Old Jun 25, 2009 | 05:34 PM
ucla bruin's Avatar
ucla bruin
What's the stock offset again?
__________________
Old Jun 25, 2009 | 05:43 PM
sTiLLBaLLiN37's Avatar
sTiLLBaLLiN37
Former Prez of LA G'Z
I think +43 and +45
Old Jun 25, 2009 | 05:51 PM
ucla bruin's Avatar
ucla bruin
I think 10mm and 10mm then. 15mm in the rear might rub with 20s. 19s, not sure, might be ok, but 10mm should be safe.
__________________
Old Jun 26, 2009 | 04:39 PM
w0ady's Avatar
w0ady
20mm if you're on stock tires. 15mm if you upgraded to wider.
i run 15mm all around with 245/275 on eibachs and no issues.
Old Jul 15, 2009 | 04:11 PM
iinviktus's Avatar
iinviktus
What brands of spacers does everyone recommend? How much should they cost? Do they usually come with extended studs?
Old Jul 21, 2009 | 10:17 AM
davv1215's Avatar
davv1215
With 15mm, do you recommend the extended studs, or can you just use the stock studs and just have the spacers between the wheel and the rotor?
Old Jul 21, 2009 | 11:08 AM
chamelieon's Avatar
chamelieon
definitely cant do that with 15mm, takes about 3/4 of the stud distance. but ichiba v2 spacers would work really well.
Old Jul 21, 2009 | 11:30 AM
Blackjack's Avatar
Blackjack
Agreed! If you have stock tires, w0 has the perfect setup with Eibachs.
GW330
Feb 2, 2024 05:41 PM
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
G37xhibeet
Nov 15, 2016 09:29 AM
Sway_NV
Aug 15, 2015 09:36 PM
MeatySock
Aug 14, 2015 08:25 AM
