VDC and slip lights come on...
Old Jun 2, 2009 | 12:16 PM
johnny872005's Avatar
johnny872005
So, I was messing with the entire instrument cluster, and steering wheel etc. (I had removed it all and put it back in). I also did the same with the glove box area.
Now when I turn my car on, the VDC/slip lights dont come on, but if I drive for a few seconds it will turn on. Also, it seems like the light coming on/off depends on what slope I'm on, because there are certain spots on my driveway that if I stop and turn the car on there, both the lights will come on before I even start driving. The VDC light will comeon and if I push the vdc off button, obviously notting happens.
Anyone have any ideas how I can fix this, or narrow down the issues? I'm pretty certain I connected every harness correctly, not sure what problem is.
Please make suggestions OTHER than take it to the dealer
Thanks
Old Jun 2, 2009 | 12:50 PM
What have you done wit your tire/wheel/suspension setup?
Old Jun 2, 2009 | 02:42 PM
johnny872005
Well I've gotten aftermarket rims/tires, but that was a while ago. I mean the car has been driving fine for a while now.
Only work I've done that could be involved in causing the light to go off, was removing the dash cluster (the thing with RPMS speed, etc) and put it back on, and same for the glove box.
I had replaced my dashboard, and I put it all back together and it worked fine, then the following day I went and fixed those two parts (the cluster and the glove box) because it was getting dark the previous day, and I just slopped those together so car would be useable. I didnt get any lights that night, but then the following day when I went in to fix them and attach em correctly, I started getting the lights.
Old Jun 2, 2009 | 02:50 PM
Mike's Avatar
Mike
Question: when the lights are lit, is your VDC functional or disabled?
Old Jun 2, 2009 | 04:41 PM
johnny872005
not sure, how can I tell? Find a puddle of water and try to peel out?
Old Jun 3, 2009 | 10:08 PM
johnny872005
anyone?
Old Jun 3, 2009 | 10:20 PM
Kidcane's Avatar
Kidcane
Florida G Club
Have you dyno'd your car? Check the brake fluid level? Did you turn off the VDC and do doughnuts?
Old Jun 4, 2009 | 12:43 PM
johnny872005
no, yes, and no lol
Old Jun 4, 2009 | 01:02 PM
Even though you think everything is back together fine, I would take it apart and double check it since you are certain that is when the problems began to occur and is the only "X-factor" surrounding their first appearance. Maybe when you threw things together hastily you may have misconnected or damaged something minor that is causing a short?
Old Jun 4, 2009 | 01:34 PM
JDM's Avatar
JDM
when it happen to me my vdc was disable
although for me the lights has gone away the last 2 weeks and i dont see them no more
misc
17
Dec 24, 2019 05:13 AM
B Feelgood
Sep 13, 2015 05:56 PM
inspector94
Sep 8, 2015 12:57 PM
ZachThomas
Sep 3, 2015 01:40 PM
