Thinking of lighweight rims to improve performance....
Old May 19, 2009 | 04:32 PM
Greggski's Avatar
Greggski
Originally Posted by TJHG37S
There's a great article in this month's Modified Mag on this subject, wheel weight is only one of several factors that ultimately affect the rotating mass...check it out, it's the one w/ the silver GT-R on the cover.
I read the article too - made me think twice about dropping a ton of cash on some forged wheels.
Old May 19, 2009 | 04:57 PM
xyz's Avatar
xyz
Cliffnotes please . . .
Old May 19, 2009 | 05:57 PM
Greggski's Avatar
Greggski
They tested 5 different rims from top of the line RE30's to cast Axis wheels. The difference in price and weight was very proportinal with the Volks being the lightest and most expensive, Zigen was in the middle, and Axis was heaviest and cheapest.
There were different tests done to determine the effect of each wheel while keeping as many variables consistent as possible (car, tires, psi, etc.) They timed each set on a figure 8 course, rotational deceleration (done on a dyno - got up to 30mph, and let free roll down to 5mph), an acceleration test (0-60 or 1/4 mile - can't remember), and a density test.
Anyways, the difference between the Axis and the Volks were very small for the street set-up / occasional track car that my G is. In fact, the Volk barely beat the Zigen that was 1/2 the price. More important is the distribution of the weight of the wheel - if the most mass is in the center near the hub or on the outside nearer the tire.
With all that though, I still like the look of the volks, the name and strength they offer so I might still get them - but am not expecting noticable gains from weight savings...
Old May 19, 2009 | 06:24 PM
xlack's Avatar
xlack
https://www.myg37.com/forums/brakes-...m-fitment.html
Old May 19, 2009 | 08:46 PM
xyz's Avatar
xyz
Thanks Greggski
Old May 20, 2009 | 03:36 AM
xyz's Avatar
xyz
Any suggestions to 19s that wouldn't cost an arm or a leg from these "2nd tier" wheel manufacturers?
Old May 20, 2009 | 01:00 PM
w0ady's Avatar
w0ady
sedans ARE lighter than coupes because coupes have extra bracing on the sides due to no middle support.
go for some strong 1 piece forged wheels. volks, gram lights, advans are all good companies to check out. check the vendors here, on g35driver.com and my350z.com for some pretty good deals. you can get good deals on 18s and spend less since 19s are bigger and tires cost more.
Old May 21, 2009 | 03:42 PM
Mike S.'s Avatar
Mike S.
One thing to keep in mind about the modified mag article. The difference in weight was only a few pounds (20.9 for the heaviest vs. 17.x for the lightest.
I'm thinking about goign from 30lbs infiniti rims to 17-18lb volks.
Old May 21, 2009 | 09:02 PM
TJHG37S's Avatar
TJHG37S
True, but you could also get something different for much cheaper and have the same effect you're looking for..
Old May 29, 2009 | 04:32 PM
UNV-IT46's Avatar
UNV-IT46
my rear ce28's were just under 17lbs and they were 19x10.5
Old May 29, 2009 | 05:05 PM
xyz's Avatar
xyz
And they are sold already . . .
Your CE28s . . . Lou's RZs . . . and Oneandonly's GTMs . . . all sold right when I'm ready to buy . . . waaaaaaaaaaaaaaaaaaaaaaaaaaaaah . . .
sorry, just ranting . . . haha . . .
Old Jun 8, 2009 | 05:20 PM
Titanium_R's Avatar
Titanium_R
I personally am a fan of the SSR type Fs. The 18s can get up to 11 inches wide. They are not as light as some of the Volks. But, pretty damn good either ways.
http://www.ssr-wheels.com/wheels/typef_1516171819.asp
Sometimes lightEST is not always the best. There are a lot of lightweight wheels out there that would bend. I also would agree with forged > cast.
To the guy that said 19 x 10.5 CE28 weighs 17 lbs. Did you shave 3 lbs out of your wheels or something? Because from my sources, and the internet, it seems that the CE28N in that size is more around 21 lbs.
http://www.upgrademotoring.com/wheel...N%2010%20Spoke
Old Jun 8, 2009 | 05:23 PM
TJHG37S's Avatar
TJHG37S
Forged FTMFW
Old Jun 8, 2009 | 05:45 PM
  #29
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
my re30 19s were ALOT lighter than stock and I could tell a big improvement in acceleration.
Old Jun 8, 2009 | 07:17 PM
  #30
Mike's Avatar
Mike
Bump for a guy with awesome intentions
