tire pressure
Old Mar 28, 2009 | 09:18 PM
jtaylor22's Avatar
jtaylor22
tire pressure
do you guys inflate your tires (stock tires & rims) to the recommended 35lbs of pressure or do u go by the max tire pressure minus whatever u feel is best for performance
Old Mar 28, 2009 | 09:32 PM
PSYH's Avatar
PSYH
Post Whore
I do 37psi for no particular reason.
Old Mar 28, 2009 | 10:18 PM
NEVER inflate your tires to the max PSI listed on the sidewall of the tire. Just inflate them to 35 PSI if you have OEM tires and be done with it.
Old Mar 29, 2009 | 12:13 AM
jtaylor22's Avatar
jtaylor22
no not to the max, but stock is max psi 51, how high would u got if u wanted to increase it somewhat?
Old Mar 29, 2009 | 12:22 AM
If you're carrying a particularly heavy load you might increase it maybe 2 or 3 PSI. I personally go up to 38 sometimes for a long road trip to get slightly better mileage, but not permanently.
Old Mar 29, 2009 | 01:29 AM
G_Thang's Avatar
G_Thang
Also depends on how much negative camber your running. I used run mine on the low side to preserve the tire since I had quite a bit of negative camber.
Old Apr 10, 2009 | 11:11 AM
WildWes's Avatar
WildWes
35 psi is fine.
RYs06MT
Apr 22, 2016 11:00 AM
Juancgn33
Sep 10, 2015 07:25 PM
mmnjtwa
Sep 7, 2015 02:27 PM
footballmania32
Sep 4, 2015 03:06 PM
footballmania32
Sep 4, 2015 02:17 PM
