For people who are dropped on htechs
Sup guys I've driven on my htechs for about 14k and my inner side on all 4 tires are worn out bad.I did get a alignment right after the drop.my question is are you using a camber kit.also what are the specs that you used to get the alignment done
I'm using the SPC rear camber kit/toe bolts. It helps a LOT.. and the computer at the alignment shop should have proper specs for you. I'm waiting on some reviews and the release of the front kit before jumping on that as well.
14K.Time to change tires
yeah.. an alignment straight after install only helps so much.. your ride will drop even more with time till it settles in and you'll need to align all over again..
mjnoles1
10-04-2015 10:27 PM
