View Poll Results: What size tires are you running on OEM 19' Sport wheels?
OEM summer performance tires
18
72.00%
Another brand's 225/45R19 (front) & 245/40R19 (rear)
0%
245/40R19 (front) & 275/35R19 (rear)
20.00%
285/? rears... Anyone running them on stock 19's?
0%
Any other tire sizes?
8.00%
Voters: 25. You may not vote on this poll
What tires are you running on OEM 19' rims?
Old Jan 11, 2009 | 07:48 PM
AndrewDDS's Avatar
AndrewDDS
My OEM Performance tires are getting to a point where I'll need to replace them soon. Like many other people on this forum, I think the stockers are a bit too skinny and don't look right on the car or the rim. So, for those of you out there with 19' Sport wheels, what kinds of tires are you running?
Old Jan 11, 2009 | 08:44 PM
I have 255/35 front and 275/30 rear on stock 19's. They fit fine. 285 will fit the stock rears but I didn't get them because the Yoko S Drives I wanted were out if stock at the time. Yokohama S Drives are treat tires. Also, 255/35 & 285/30 are the best plus 0 sizes closest to OEM diameter/circumference to maintain suspension geometry and speedometer/odometer accuracy.
Old Jan 11, 2009 | 10:31 PM
AndrewDDS's Avatar
AndrewDDS
I would love to go all the way to 255/285!! Is your G dropped at all, or stock suspension? I'm currently having Eibach Pro Kit springs installed; so I'm concerned that 255 fronts will rub. For that matter, 285 rears might rub. How is the noise with all that rubber?
Old Jan 11, 2009 | 11:07 PM
Significantly quieter than OEM tires. Dropped on Tanabe NF210 which is a very similar to the Eibach Pro Kit. No rub at all front or rear, not even close. I even checked while I had 4 full sized adults in the car. Close in the rear with all that weight, but no rub with 275. After double checking on the 285 width, the guideline is for 9.5"-11" wheels and ours are only 9" wide, but I bet they'd work and fit safely.
Do it!
Old Jan 11, 2009 | 11:26 PM
AndrewDDS's Avatar
AndrewDDS
I just found this awesome link in another thread!
http://www.miata.net/garage/tirecalc.html
It looks like the closest I can get to spec while increasing my width is 275/35-19 on the rears and 255/40-19 on the fronts. That keeps me within 3% of spec. Now I just have to find all-season tires that come in those sizes....
Old Jan 12, 2009 | 12:14 AM
VIP G's Avatar
VIP G
225/45/19 up from OEMs with 55% tread left
275/30/19 Vredsteins with 95% tread left
Old Jan 12, 2009 | 08:27 AM
NotUrG's Avatar
NotUrG
The Vredesteins are great tires- I will be purchasing those when my OEM's are shot.
Old Jan 12, 2009 | 10:49 AM
marsb007's Avatar
marsb007
245/40/19 front
275/35/19 rear
Michelin Pilot Sport A/S Plus
Old Jan 12, 2009 | 07:39 PM
w0ady's Avatar
w0ady
just got my nitto invos mounted today.
245/40/19
275/35/19
was actually going with yoko s.drives but they were on backorder. liked my toyo t1-r's before but wanted to try something new.
im sorry but thats wrong. those sizes are closer to 4% different from oem diameters vs 1% with the sizes i listed.
Old Jan 12, 2009 | 08:21 PM
ucla bruin's Avatar
ucla bruin
How about people with 20s?
I think jedmond rubs with 285s
__________________
Old Jan 12, 2009 | 08:25 PM
B L U E S L A T E's Avatar
B L U E S L A T E
If money wasn't an issue, I'd personally rock a set of PS2s on the stock 19s, 245/275 in sizes.
Old Jan 12, 2009 | 08:37 PM
245/40/19
275/35/19
You sir, are correct regarding the fronts. The rears however is a 4.6% difference in 275 and only 3.7% in 285.
My mistake is that the widths I listed are only .1% and .2% different size in 20" diameters, not 19" my bad. Hope I didn't screw anyone up. I gots dubz on the brain.
Old Jan 13, 2009 | 06:35 PM
w0ady's Avatar
w0ady
actually for 20s id recommend:
245 or 255/35/20
275 or 285/30/20
Old Jan 13, 2009 | 06:59 PM
245 or 255/35/20
275 or 285/30/20
Kind of like what I said back in post #2 except I said 19" and meant 20"?
Old Jan 13, 2009 | 10:44 PM
ProstylezG37's Avatar
ProstylezG37
Im sittiing on H&R's...will something wider then the stock 245's in the rear rub?
KAHBOOM
Aug 25, 2015 11:05 AM
RoyalG37
Aug 11, 2015 12:21 PM
zzww1251
Aug 8, 2015 06:19 PM
Hiryuu
Aug 7, 2015 07:08 PM
