Help need help on Spacers
thanks for the info, im just gona go 15mm all around for now, and ill buy the inchiba spacers because they make them for the G37, unlike the eibach there only for the 350z, but could be used for the 37, but not safe in my book.
Without a doubt you MUST do the longer studs with a 15MM spacer or you will have very little thread to tighten the lugs on. Talk about not safe!!
Oh and the Eibachs for 350 are identical, it is based on the hub size which is the same on 350 as G35 as G37
Kojack
Oct 9, 2015 05:53 PM
nbast
Sep 14, 2015 12:39 PM
