rotor question
Old Oct 7, 2008 | 03:20 AM
NeverBoneStock's Avatar
NeverBoneStock
rotor question
Does anyone know of a company that offers a 2 piece drilled and slotted rotor direct oem replacement for the G37 S ??????? Any suggestions ????
Old Oct 7, 2008 | 09:55 PM
bboysteele's Avatar
bboysteele
I thought Stillen or another company had something out. I thought there was an old thread on it. I will see if I can find it.
Here it is: https://www.myg37.com/forums/showthr...=180715&page=2
Old Oct 8, 2008 | 03:23 AM
NeverBoneStock
Any other suggestions ????????
Old Oct 8, 2008 | 09:56 PM
pdarby's Avatar
pdarby
I've been looking and asking everywhere, no one has them out yet for the G37 unless you want to convert to Brembo. Which I could find some
Old Oct 8, 2008 | 10:08 PM
RedG37SNC's Avatar
RedG37SNC
Brake Performance can do drilled and slotted rotors however they would not do them for the G37. Andy said our cars are to heavy for them and said they were for cars like mustangs and lighter as far as doing an OEM replacement. Dimpled and slotted is all that's out there now to my knowledge.
Old Oct 8, 2008 | 10:09 PM
bboysteele's Avatar
bboysteele
I forgot to post this as well.
http://www.stillen.com/product.asp?i...odel=G37%202DR
Old Oct 8, 2008 | 10:16 PM
RedG37SNC's Avatar
RedG37SNC
Note, non-S rotors and no rears.
Old Oct 8, 2008 | 10:25 PM
bboysteele's Avatar
bboysteele
Crap, I missed that....
Old Oct 9, 2008 | 10:43 AM
Seer's Avatar
Seer
Mustang GT's weigh 3550lbs
G37S weighs 3616lbs
Old Oct 9, 2008 | 01:42 PM
RedG37SNC's Avatar
RedG37SNC
I imagine he was refering to earlier model stangs.. either way BP would not do drilled on our OEM rotors, that was my original request as well.
Old Oct 9, 2008 | 02:09 PM
NeverBoneStock
Well looks like im schit out of luck .....
Old Oct 14, 2008 | 08:12 PM
herrjr's Avatar
herrjr
Stoptech offers replacement 2-piece rotors for Brembo-equipped G35s, so perhaps if we both go to them and say we want these rotors for the Akebonos they'll fulfill our request lol.
Old Oct 14, 2008 | 11:46 PM
Rollin'onRays's Avatar
Rollin'onRays
Maybe i am crazy and have been taught incorrectly, but slotted and drilled rotors aren't that good unless you are wanting them for looks. Drilled, unless i was taught wrong, was only used back in the day so that gases from the brake pads could escape the rotors. brake pads now-a-days don't expel gases nearly as much as before, and don't need the holes to escape. Also, the slotted part is only used to make sure the face of the brake pad is new for a good bite all the time. Also, having slotted and drilled rotors means less mass for the brake pads to expel heat through, in turn giving less braking power. Braking power is really the ability to turn rotational power into heat to slow down. If you look at any real race car that isn't for looks, i don't really recall any using drilled or slotted rotors. If they were that good, wouldn't F1 be using them?
if you want looks and more brake dust, drilled and slotted are the way to go!
Again, this was always what i was taught, maybe i am completely wrong
Old Oct 14, 2008 | 11:59 PM
Seer's Avatar
Seer
drilled rotors tend to crack, slotted only are still used for cooling purposes.
Old Oct 15, 2008 | 12:00 AM
speedracer g37's Avatar
speedracer g37
gasses build up between the pads and rotors causing fade loss of braking power. slots and holes allow these gasses to escape. also, the lower mass of drilled and slotted rotors allows them to cool more quickly.
