Tire / Suspension Problem
Old Jun 23, 2008 | 02:16 PM
ChimChimG37's Avatar
ChimChimG37
Just replaced OEM wheels with 20" Sevas Forged 55 in a staggered set-up with 245/35 in the front and 285/30 in the rear. Tires are Nitto Invo. Wheels and tires look awesome but...on higher speed compressions tire is definitely making contact with something other than the road (suspension, body?).
Has anyone had a similar issue and what is the fix?
Old Jun 23, 2008 | 02:31 PM
finagle69's Avatar
finagle69
Are you dropped? If so, using what?
I'm running 245/35/20 and 275/30/20 on coilovers with a pretty low drop with minimal rubbing.
Old Jun 23, 2008 | 02:45 PM
ChimChimG37
No drop, stock suspension.
Old Jun 23, 2008 | 02:53 PM
The1andOnly's Avatar
The1andOnly
What size wheels and offsets are you running?
Old Jun 23, 2008 | 03:00 PM
ChimChimG37
10.5", believe offset is +20
Old Jun 23, 2008 | 03:04 PM
The1andOnly
Your most likely rubbing in the rear with that set-up. I'm only getting 19s in a 10.5 +34 and the biggest I can run is a 275.
Put some 275's in the rear and that sould take car of it, although that's a pretty agressive offset as well for our cars.
Old Jun 23, 2008 | 03:20 PM
finagle69's Avatar
finagle69
did Sevas make the wheels specifically for your car or did you get them from a place that had them in stock for the G35?
like T1aO said, that's a very agressive offset and is the main reason for your rub.
Old Jun 23, 2008 | 03:37 PM
ChimChimG37
Made to order. Offset is +26mm. Nitto doesn't make the Invo in a 275/30, will 275/35 fit? Would stiffer suspension work?
Old Jun 23, 2008 | 03:45 PM
The1andOnly
No, its not the suspension. It's the wheel and tire combo. Yeah the 275/35 should hepl to fit. The sidewall size doesn't really make the difference, it's the width.
Old Jun 23, 2008 | 04:01 PM
ChimChimG37
Appreciate the thoughts -- the kids needed new tire swings anyway!!! Next up: Carbon Fibre Grille and New LED Dome Light.
Old Jun 23, 2008 | 04:49 PM
finagle69's Avatar
finagle69
man, i don't even think the 5mm thinner width tire will save you. that is a crazy offset on a 10.5" rim.
if you drop the rear AND put a 275 width tire on, you may be ok.
Old Jun 23, 2008 | 05:13 PM
jedmonds's Avatar
jedmonds
I have the same wheels. I had to run 275's in the rear, and shave the little tab that connects the rear bumper to the car, and it got rid of my rubbing issue.
Mattlorentzoe
May 24, 2021 08:49 PM
socialconflicts
May 28, 2020 12:03 PM
m3clubracer
Sep 11, 2016 09:01 PM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
