Anyone running BC coilovers
Old May 1, 2008 | 01:22 AM
bboysteele's Avatar
bboysteele
Originally Posted by AZg37
just a quick novice question. What is the major difference, or advantage of having the BC kit vs. let's just say the Tanabe nf210 springs? I'm only wanting about 1 inch drop all around and Tanabe gives about that for a lot cheaper? Again, please be kind, because I've never understood suspension
From what I have been told you can adjust the height of the BCs where as with just springs you are stuck with whatever the drop is. Also you can adjust the stiffness (dampening I think) to make it more of a stiff ride or cushioned ride.
Old May 1, 2008 | 01:34 AM
TerribleONE453's Avatar
TerribleONE453
yea you are adjusting the dampening when you change the stiffness.. And also being able to play with your ride height just incase you change your mind or want to go to a track or something you have the ability to change your ride height and stiffness... coils are the way to
Old May 1, 2008 | 01:41 AM
AZg37's Avatar
AZg37
bare with me here. What height do they come? Like, do you install them, then tinker with them to adjust the ride? Do you measure them and adjust before install? How easy is it to adjust height and stiffness while installed on the car, just pull the wheel and click away?
Old May 1, 2008 | 01:50 AM
TerribleONE453
the height you will need to take off your rim... and the stiffness is just a turn of a ****... VERY easy.. you adjust the height when its on the car...
Old May 1, 2008 | 01:53 AM
AZg37's Avatar
AZg37
whats the max drop for the BC's? when adjusting height, are there like labled intervels, or are you guestimating, going off of how it looks?
Old May 1, 2008 | 02:00 AM
TerribleONE453
you pretty much guess and the max drop is so your car will take out road markers
Old May 1, 2008 | 02:03 AM
AZg37's Avatar
AZg37
nice
Old May 1, 2008 | 04:01 AM
chucky's Avatar
chucky
More Questions
I read in one of the posts that 12/8 is the ideal setting for the dampeners as far as comfort and a reasonable stiffness is concerned. I assume that is 12 clicks for the front and 8 for the rear. I don't know where to start making the clicks from. Do I go max softness and do 12 clicks toward the hardest setting or is it the oppisite hard to soft? I know I will be able to change the settings easily but want to start out at a good point before I install them. Is there a good place to start for the height? Like a measurement for the length of the dampners to be set at before install. Want to start at an inch all around but also read that 1" front and .8" rear is the ideal drop. Sorry for all the questions but the instructions leave a lot to be desired. Plan on doing the install this weekend. Praying my wheels come by then if not, I'll put them on later.
Old May 1, 2008 | 09:28 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^Actually I think the 12/8 you are refering to is the spring rates not the dampening. I run mine at 13 of 30 in the front and 15 of 30 in the rear for daily driving. I am still playing with them trying to find the happy medium between too stiff for DD and still good performance.
Old May 1, 2008 | 11:25 AM
chucky's Avatar
chucky
Kidcane thanks for the input. I'm thinking I'll measure my old units when I take them out and then shorten the new units about an inch before installing them. Does that make any sense to you?
Old May 1, 2008 | 08:14 PM
sharif@forged's Avatar
sharif@forged
Chucky, make sure to start a nice thread with some pics once you get those wheels and coilovers installed. I can't wait to see them.
Old May 1, 2008 | 09:08 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
mine stiffness it set at 20 in the front and 25 in the rear
Old May 3, 2008 | 03:04 AM
chucky's Avatar
chucky
Last minute advise please
no new wheels. Kidcane, you are right about the 12/8 I must of had a senior moment What do you think about measuring the old struts then shorting the new ones about an inch before installing them? Also, after inital install and I start adjusting the struts do you or anyone else have an idea of how much a full turn at the bottom of the strut will raise or lower the car? Or should I give it a day or so for the springs to settle? Also,on the dampning did you start at the softest or hardest setting? I'm doing the install tomarrow. I'll take heed of all the great advise. Thanks again, wish me luck. I'm a decent mechanic but this is my first go around with coilovers. I'll check for last minute advise before I install.
Old May 3, 2008 | 10:50 AM
  #29
sharif@forged
wheels will be there on Tues.
Old May 3, 2008 | 11:49 AM
  #30
MaxToTheG37
When your adjusting the struts one full turn will not be noticable... these are very tunable... but with the way there on there you cant turn full turns... each turn will be prolly between a 1/4 and a 1/2 turn. just turn them suckers and measure... its really about trial and error... you just need to make sure your raise and lower the strut the same amount you raise and lower the spring...
PM me or IM me if you have any questions... Sharif did a great job at teaching me how and talking me through the adjustment part of it! so i can help out a little bit ...
