Steering Wheel Vibration @ highway speed
Old Apr 2, 2008 | 09:11 PM
brrrtpoypoy's Avatar
brrrtpoypoy
Just wondering if anyone else on here has experienced this? My steering will shake @ about 110-130km/hr, the car itself doesn't shake along with that, it's just the steering wheel. Also, just to add, i haven't hit anything or gone over any crazy bumps, this car is rarely driven.
Does anyone on here know what could possibly be causing this? I've had my car for about 5 months with 4800km on it and just noticed this vibration now.
I hope someone can fill me in,
Thanks in advance.
Old Apr 2, 2008 | 09:22 PM
palinka's Avatar
palinka
It it only shows up at certain speeds, then it's most likely one of your wheels that is out of balance. Check for missing wheel weights.
Old Apr 2, 2008 | 10:01 PM
Kidcane's Avatar
Kidcane
Florida G Club
^^+1 probably something simple like that.
Old Apr 2, 2008 | 10:38 PM
beestea's Avatar
beestea
Mine is completely smooth...
BTW, has anyone noticed how many stick on weights the factory uses to get the perfect balance?
I swear one of my wheels has like 10+ weights on it.... I have a feeling when I need new tires/balance it will never be quite as good as factory.
Old Apr 2, 2008 | 10:55 PM
DiamondGCoupe's Avatar
DiamondGCoupe
So it feels great when you test drive it.
Old Apr 2, 2008 | 11:02 PM
solopresident's Avatar
solopresident
alignment or wheel balance. go to dealer.
Old Apr 2, 2008 | 11:49 PM
It varies, might be none and might be a lot depending on the balance of the individual wheel/tire combo. There is no standard number. Occasionally you will get a defectively built tire that will not balance no matter what you do.
If you get a high speed vibration, it is almost always a wheel balance issue. Particularly if you get it at higher speeds and only in a relatively narrow speed range as you describe. The dealership will correct if for you at no charge and it shouldn't take long.
Old Apr 3, 2008 | 09:23 AM
Callaway's Avatar
Callaway
Arm flailing tube man
^^+1 should be an easy fix.
Old Apr 10, 2008 | 12:54 AM
shabbo's Avatar
shabbo
It should be perfectly smooth! if the steering weel shimmers then it's one of the front wheels. Check with the dealership.
Old Apr 13, 2008 | 03:29 AM
UNV-IT46's Avatar
UNV-IT46
mines smooth like butter...
Old Apr 13, 2008 | 05:10 AM
solopresident
love how he starts but then goes away. was going very fast today on way home from a party, perfect.
Old Apr 13, 2008 | 05:12 AM
TerribleONE453's Avatar
TerribleONE453
lol yup never had any problems... go to the dealer...
Old Apr 13, 2008 | 01:52 PM
UNV-IT46's Avatar
UNV-IT46
were you drinking?
Old Apr 13, 2008 | 06:16 PM
TerribleONE453
hahah hope not solo... not worth spilling your drink
Old Apr 13, 2008 | 06:52 PM
UNV-IT46's Avatar
UNV-IT46
also check your wheels. see if one is missing some weights on the inside. that could cause your problem and since we use stick on weights its always possible...
Ryne
Jan 18, 2016 05:39 PM
joeposter
Sep 8, 2015 04:36 PM
xpcgamer
Sep 5, 2015 09:28 AM
mauiwowie
Aug 16, 2015 06:01 PM
