Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Stuck nuts front lower control arms
Old Feb 21, 2023 | 06:25 PM
corn's Avatar
corn
So to start, both nuts and probably bolts for the front end lower control arms are stuck, which I've learned is a common issue. Tried heating, 750ft lb impact, penetrant, nothing worked, so I decided i need to cut it.
Went to remove the brake caliper to have room to get in with a sawsall and both bolts holding it on are stuck. I don't think i should heat it because it's aluminum. This is the first mod I've tried doing to my g and it seems it may be over my head.
I'm looking for advice to get the bolts attaching the caliper to the knuckle, or should i just give up and take it to a mechanic? its pretty disheartening when 1/2 of the nuts are stuck, these aren't even the only ones
Old Feb 23, 2023 | 01:52 AM
corn's Avatar
corn
Update: I got all of them after applying penetrant, torching it, and torquing the **** out of it daily. But now the stud that goes into the knuckle connecting the lower arm snapped. Lol
Old Feb 24, 2023 | 03:08 PM
socketz67's Avatar
socketz67
Community Builder
The bolt that goes into the knuckle connecting the lower arm should be something you can replace? Why are you replacing the lower arm[s]? Bad ball joints?
Old Feb 25, 2023 | 01:29 PM
corn's Avatar
corn
The bolt that goes into the knuckle connecting the lower arm should be something you can replace? Why are you replacing the lower arm? Bad ball joints?
I think i can, I just bought a bolt extractor bc the head snapped off. I was installing coil overs. I think this is a dead thread now I may delete it if I can, thanks for asking though
G3727
Dec 3, 2021 10:21 PM
Dough1397
Aug 13, 2019 03:33 PM
Mg37
12
Aug 25, 2016 12:38 AM
JT2014
Nov 20, 2014 08:47 AM
TVPostSound
19
Dec 24, 2013 01:50 PM
