Help tein s spec lowering springs & 20mm spacers all around without a camber kit
Do I need a camber kit with tein s spec lowering springs & 20mm spacers
So I just ordered tein s-spec lowering springs, from what it says online should be close to a two inch drop all the way around on the sedan. I also got 20mm spacers all the way around that I plan to fix the fitment a bit more with. Going to get the springs installed at a local shop , and try to have a alignment done , not sure if it’s possible to align it without a proper camber kit , my fear is uneven tire wear so if I can prevent it I would invest in a camber kit , just wanted to know if it’s possible to run the springs and spacers with no other modifications, besides a alignment.
So I have a 2012 g37s sedan, I ordered tein a spec lowering springs and 20mm spacers, I wanted to know if it’s possible to run these mods without a camber kit to get aligned, my issue is a don’t want uneven tire wear if I run this without a camber kit , or is it even possible to get a allignment with a camber kit with around a 2 inch drop all the way around from the teins
