Mechanical-vibration when putting on brakes
Old Aug 29, 2020 | 05:42 PM
Matt Gurksnis's Avatar
Matt Gurksnis
Hi,
First time post on this forum. Hopefully I am clear and concise.
Vehicle: 2012 Infiniti G37 Sedan
1) In November 2019 I replaced front brakes and rotors because I was getting vibration/wobble sensation in the brake pad and steering wheel, usually when applying brakes at higher speeds. Bought rotors and brakes from Autozone.
2) In June 2020 I noticed the vibration/wobble sensation again when applying brakes. I took off brakes and rotors again and switched them for another set from Autozone ( I thought maybe the first set I bought weren't good). This change seemed to fix the problem.
3) Beginning in August I noticed that when i would get speed up to 70-75mph I was getting a vibration/wobble in the front (not when applying brakes). I had the front tires checked and both front tires had significant wear on the inner part of the tire. When I replaced the tires my problem in number 2 above was resolved.
4) Today I noticed that I am getting the vibration/wobble again when applying brakes at higher speeds.
My question, outside of rotors what might this be? Could it be rear rotors? (how can i determine if it is the rear). Bad front calipers (just a guess)? Maybe tire rods( I looked and nothing to my eye seems worn), car does have 85K miles. Is there a certain type of rotors specific to this vehicle that I must use? I don't notice any alignment issue while driving but since my tires did wear on the inside should I get an alignment?
Any suggestions are appreciated.
Thanks
Matt
Old Sep 2, 2020 | 03:39 AM
Said Amir's Avatar
Said Amir
1) Make sure you're greasing all the pins, and the edges of the pads where there is metal contact too calipers, so it can slide in and out smoothly.
2) Make sure you're torquing your wheels. This really does make a lot of difference and can cause the rotors to warp.
3) After installing the pads and rotors make sure to go and break them in. See the recommendation from the company. There is videos on this on youtube also.
4) You can also bleed the brakes
fgxmfmq
Sep 7, 2013 09:46 AM
mprog
Mar 27, 2013 01:03 PM
myg37journyspor
Sep 5, 2011 10:24 AM
Victor_minator
Jun 21, 2010 08:19 PM
DanMardik
31
Apr 20, 2009 12:32 PM
