08 G37 coupe and sedan same strut?
Old Feb 8, 2020 | 06:33 PM
Spec7's Avatar
Spec7
i tried searching, but wasnt able to find anything solid - do the 08 g37 sedan strut/spring fit a 08 coupe?
Old Feb 9, 2020 | 12:24 AM
PNW_IPL's Avatar
PNW_IPL
the coupe struts are alot shorter than the sedan. The spring rates and damping is different as well. Physically they'll fit but I can see the sedan combo on a coupe being an issue if your lowering.
Old Feb 9, 2020 | 12:27 AM
Spec7's Avatar
Spec7
thanks for the response! do you happen to know if the 2013 g37 struts/springs will fit the 08?
Old Feb 9, 2020 | 04:53 AM
PNW_IPL's Avatar
PNW_IPL
Yes they will fit physically
Old Feb 9, 2020 | 10:17 AM
slartibartfast's Avatar
slartibartfast
Sedan springs on a coupe is a very mild drop as the coupe is heavier than the sedan. The drop might be all of an eighth inch.
Old Feb 10, 2020 | 02:16 PM
Spec7's Avatar
Spec7
Sedan springs on a coupe is a very mild drop as the coupe is heavier than the sedan. The drop might be all of an eigth inch.
Thanks for the specifics!
My6speedCoupe
Brakes
Oct 29, 2008 04:14 PM
KDG35
Mar 21, 2007 04:42 PM
