Centric Rotors vibrate
Old Aug 15, 2019 | 07:05 AM
Snaoum's Avatar
Snaoum
I have a 2011 G37xS sedan. I have been noticing the above 40mph when I brake there is a big of vibration, feel it in the seat and steering wheel. I had installed Centric rotors (front/back) back in July 2017 along with new pads and did the whole bedding process. I drive about 15 miles a day. I kept reading it is probably not warped rotors but pad deposit. I went ahead and tried to clean them out by doing several 60mph down to 10mph braking with no luck. Just few days ago I went ahead and replaced all the pads with new pads and bed them in. It still feels the same, great stopping power but not smooth. Anything else I can do other than replace 4 rotors again?
Old Aug 15, 2019 | 10:32 AM
Surfnazi's Avatar
Surfnazi
Seems one of your pistons in the caliper is binding. Buy rebuild kit for seals
Old Aug 15, 2019 | 12:05 PM
Snaoum's Avatar
Snaoum
Why do you think it is a caliper that is binding? Even if that is the case, is there any way of knowing or does one just rebuild all the calipers? I have done the passenger rear before but it is not a hard job.
Old Aug 15, 2019 | 12:18 PM
Surfnazi's Avatar
Surfnazi
New pads and rotors warping usually is caused by piston seal going bad
Old Aug 15, 2019 | 01:50 PM
slovell1's Avatar
slovell1
Warped rotors can also be caused by not torqueing the lug nuts on your wheels to spec.
Old Aug 20, 2019 | 07:21 AM
Snaoum's Avatar
Snaoum
I would check the torque of all the lug nuts. I will admit I have been using an electric impact gun to tighter the wheels.
Old Sep 4, 2019 | 02:29 PM
Snaoum's Avatar
Snaoum
Solution was to replace the rotors. I purchased 4 new rotors from RockAuto. I went with coated Raybestos rotors, came to about $108 and they are coated and should not rust.
Old Sep 5, 2019 | 05:01 PM
slartibartfast's Avatar
slartibartfast
There was nothing wrong with your rotors that an Italian tune-up wouldn't have fixed. For free.
main_shoby
Jan 11, 2017 11:04 AM
delfin2003
Jun 26, 2016 09:17 PM
Treyman42
Oct 5, 2014 10:49 AM
Dough1397
May 31, 2013 11:43 AM
ZenZiglar
Feb 26, 2013 05:42 PM
