Help Z1 Motorsports brake line issues. Anyone had THIS??? *pics*
Old Jul 14, 2019 | 01:53 AM
Shurik355's Avatar
Shurik355
I did an Akebono brake upgrade a few years ago on my G. Went with the Z1 Motorsports "Premium" Stainless Steel Brake lines. Noticed today that my passenger front side is cracking. Need to replace it asap. Anyone had this problem with their lines????
Old Jul 14, 2019 | 12:42 PM
slartibartfast's Avatar
slartibartfast
That's just the poly sheath failing due to the very sharp angle. The braided steel sheath and the teflon inner line are fine.
Old Jul 14, 2019 | 01:12 PM
Shurik355's Avatar
Shurik355
I remember when installing it, the line didn't have enough slack and had this sharp angle. Poor design due to short lines? I tried getting as much slack as possible there and that's the best i could have gotten, and now over time this is the result.
It appears it has a small leak there or something? brakes feel just fine and the fluid is all full, but where it's ripped there it has a oil residue around it.
Old Jul 14, 2019 | 01:58 PM
JSolo's Avatar
JSolo
Just say no!!!!!
As you mention, bend is too sharp. You'd have no brake pedal if you had a leak of the internal line. Have you reached out to the seller to see if they'll replace 'em (hopefully with an updated longer line)?
Old Jul 14, 2019 | 02:45 PM
KidJai06's Avatar
KidJai06
Are you able to adjust the bracket for the brake line on your coilover lower? That may get you a little slack.
Old Jul 14, 2019 | 04:23 PM
PNW_IPL's Avatar
PNW_IPL
Lower the bracket. Hopefully doesn't pull on the other side
Old Jul 14, 2019 | 10:22 PM
Shurik355's Avatar
Shurik355
Thanks for the responses guys. The only way I can find a little slack right now is bending the bracket somehow or lowering the brake line mount that is around the strut all the way down. That's really all I can do. It really needs longer lines in order to make it work perfect.
And yes I reached to the Z1 guys and just waiting for their response this upcoming week.
Thank God it's not leaking, but over time it might. It's strange is has an oil residue around the rip but no leak seems like.
Old Jul 18, 2019 | 02:30 PM
antirice's Avatar
antirice
hmmm, i have the same brake lines and mine don't have those sharp bends. Maybe it's the shocks, I noticed on yours the square block thing on the shocks sits way higher than the other one bolted to the suspension.
Old Jul 21, 2019 | 11:47 PM
Shurik355's Avatar
Shurik355
yeah I think its the location of the line mount on the BC BR coilover shock that I have here.
Old Jul 26, 2019 | 04:26 PM
Surfnazi's Avatar
Surfnazi
Goodman are good as lines
MiPwnYew
May 2, 2014 08:48 AM
JEBperformance
Brakes/Suspension
30
Apr 2, 2012 11:29 PM
CharlieMac646
Dec 10, 2011 09:59 AM
GTM
Dec 30, 2008 05:54 PM
