Rear camber / toe set which does not hit sway bars?
Old May 12, 2019 | 12:07 PM
iCrap's Avatar
iCrap
So I need to get a rear camber arm / toe bolt set for my car. i was all set on SPC before I started reading about the curved vs straight arms and hitting aftermarket sways. I have the Hotchkis sway bar set. Does anyone know what arms are compatible? Everything I have found is a totally straight arm.
Old May 12, 2019 | 12:40 PM
I've the SPC, it's straight and very close to my Eibach sway bar, but there's no actual contact. Don't know about Hotchkis.
Old May 12, 2019 | 12:54 PM
iCrap's Avatar
iCrap
Doesn't hit on compression? That was the issue I had seen when digging through old threads. Hotchkis bar is 28.5mm and apparently Eibach is 29mm. Do you have the SPC SPC72260?
Old May 12, 2019 | 01:37 PM
I've never heard anything go bang, and have never seen any smash marks. I believe these parts travel together, keeping an equidistant clearance. No, I don't know the part numbers. Bought the SPC arms and toe bolts here in a FS thread like 5 years ago.
I may not be the right guy to give you a solid answer. But like I said, small gap, no problem, SPC and Eibach.
Old May 12, 2019 | 02:41 PM
slartibartfast's Avatar
slartibartfast
I have the Hotchkis bar and SPC 2nd-gen parts and have no known contact. I can't remember whether the curved or straight camber arm is 2nd-gen.
Old May 12, 2019 | 10:57 PM
PNW_IPL's Avatar
PNW_IPL
I had eibach with voodoo13 straight arm. No contact ever.
Old May 13, 2019 | 08:54 AM
iCrap's Avatar
iCrap
From what i read the newer design is the straight one.
Ok so ill go ahead and order them then, thanks guys
Old May 13, 2019 | 08:59 AM
Baadnewsburr's Avatar
Baadnewsburr
I have the SPC straight arms with the Hotchkis sways on my 07 x sedan...no noises or contact ..I\m not sure if the actual camber you run or ride height makes a difference though...I'm lowered on swifts
Old May 13, 2019 | 01:46 PM
slartibartfast
It's not the camber that is of consequence, it's the arm used to manage the camber that can cause interference. If the stock arm can do it, you're golden. If not, you worry.
halfshaft
Dec 14, 2013 07:07 PM
CHEFONE
Apr 11, 2012 05:14 PM
christian655321
Jan 1, 2011 12:26 AM
Kev@US-Autotech
Brakes/Suspension
263
Feb 5, 2010 02:48 PM
