Special *** STILLEN *** Exhaust, Intake, Pulley, Camber, Toe Arms, & Sway Bars ********
Old 02-18-2009, 01:55 PM
Kev@US-Autotech
Kev@US-Autotech's Avatar
As one of the biggest Stillen distributor, we are proud to bring fine Stillen products to G37 owners.
1. Stillen G37 Dual Exhaust System
Application : 2008+ G37 2DR
Dual Wall Tip 504400 -------> PM for Price
Slash Cut Tip 504401 --------> PM for Price
STILLEN's Cat-Back Exhaust for the 08 G37 is built for power. Power that you can feel across the power band with a big gain on top. Mileage gains during highway travel can be expected as you cruise at steady speeds. The free flowing performance mufflers and tips are made out of polished stainless steel for long life. The Stillen fit and finish is second to none. The improved airflow created by the addition of the exhaust is verified by the significant dyno HP increase.
Dyno ---> http://www.stillen.com/product_files/504400~dyno.1.pdf
Sound http://www.youtube.com/v/uGkUAx0zPm8&hl=ko&fs=1"
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/uGkUAx0zPm8&hl=ko&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/uGkUAx0zPm8&hl=ko&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
2. Generation 1 Short tube Dual Intake Kit
Application : 07~08 350Z
07~08 G35 Sedan
08+ G37 2DR
Model No. 402838 -----------> PM for Price
STILLEN Generation 1 Short Tube Dual Hi-Flow Intake Features:
- True Cold Air design via Urethane Boxes
- Genuine K&N Filters - Dual Cone w/Integrated Velocity Stack
- Filters have a 1,000,000 Mile Warranty from K&N
- No Check Engine Light (CEL) Problems
- Ease of access to filter elements
- No Chance of Hydrolocking
- Easy to Follow Instructions
The STILLEN Generation 1 Short Tube Intake is mild under cruising situations, and really comes to life creating an impressive intake note under acceleration. The Generation 1 kit offers great sound and performance in an economical package that is also easy to install.
3. Generation 2 Long Tube Dual Intake Kit
Application : 07~08 350Z, 370Z
07~08 G35 Sedan
08+ G37 2DR
Model No. 402843 -----------> PM for Price
dyno -----------> http://www.stillen.com/product_files/402843~dyno.pdf
STILLEN Generation 2 Long Tube Dual Hi-Flow Intake Features:
- Polished Aluminum Mandrel Bent Pipes Completely Replace Factory Tubes
- Silicone Connectors
The STILLEN Generation 2 Long Tube Dual Hi-Flow Intake is mild under cruising situations, and really comes to life creating an impressive intake note under acceleration.
4. Generation 3 Ultra Long Tube Dual Intake Kit
Application : 08+ G37 2DR & Sedan
Model No. 402846/402847 -----------> PM for Price
dyno ----> http://www.stillen.com/product_files/402846~dyno.pdf
STILLEN Introduces the All New Generation 3 Ultra Long Tube Intake for the G37
STILLEN was the first national tuner to introduce a high flow intake for the G37 Coupe. Our first short tube intake provided a small boost in power with a great sound. Economical and easily installed, this Generation 1 Short Tube Intake became instantly popular. Some months later we introduced our Generation 2 Long Tube Intake, featuring polished tubes, even better sound and a power gain over the Generation 1.
Our continuing dedication to getting the maximum performance from each vehicle has lead to the introduction of our new Generation 3 Ultra Long Tube Intake. This intake has a radically new design that provides dramatically better power than any G37 intake on the market. Our R&D team went through over 50 variations before being satisfied that this system is the best that can be made for the G37 Coupe and Sedan.
The new Gen 3 Ultra Long Tube Intake places two large K&N filters in front of the radiator and directly behind the main grille. Strategic placement of the filters allow for optimum cold air flow and easy filter removal for cleaning. It features additional polished tubes that pass through the front core support, larger air filters than the Generation 2 unit, a urethane splash guard to help protect the filter and a system of varied diameter tubing and steps to maximize air velocity.
The power result: A dyno-proven 18.5 horsepower gain at the wheels on the G37 Coupe. This translates to an estimated 22 horsepower gain at the flywheel! For G37 Sedan owners, gains are 14 horsepower at the wheels. No other intake for the G37 can match these power gains!
Recommended installation requires removal of the front fascia clip (not absolutely necessary, but significantly aids in ease of installation) and slightly enlarging the holes through the front core support. Installation time is estimated at two hours for an experienced technician. No other part relocation or parts removal is required.
5. Performance Lightweight Standard Crank Pulley
07~08 G35 Sedan
08+ G37 2DR
09 G37 Sedan
Model No. 400338 --------> PM for Price
STILLEN has long manufactured precision pulleys for our supercharger kits. We have used this expertise to produce a new line of high performance crank and accessory pulleys.
Each pulley is machined from 6061 aerospace grade billet aluminum with a bold new design to maximize performance, strength and minimum weight. 304 stainless steel sleeves are used for main seal contact points for durability. Stock timing marks are maintained and keyways are precision broached. All pulleys are CNC turned, milled and balanced based on computer generated designs.
Up to 80% lighter weight than stock steel and up to 10% lighter than other aftermarket pulleys, we've seen power gains of up to 10+ HP at the wheels.
6. Camber Adjuster & Toe Arms
Rear Camber Adjuster 308375 ----> PM for Price
Rear Adjustable Toe Arms 308380 ----> PM for Price
Complete Rear Kit 308385 ----> PM for Price
7. Sway Bars
Sport only 304375 --------> PM for Price
These bars are made from high strength aircraft grade steel. Such a strong material is required for maximum torsional strength and durability.
Some sway bar kits are adjustable, allowing drivers to adjust the ride from 7% to 70% stiffer than stock, making the vehicle pleasant on the boulevard and aggressive at the track
All STILLEN Sway Bars come complete with quality hardware and installation instructions (when applicable/necessary).
Kev@US-Autotech is offline
Old 02-18-2009, 05:58 PM
Kev@US-Autotech
All PMs replied
Old 02-18-2009, 06:05 PM
wakeboardr116
wakeboardr116's Avatar
So whats the verdict on the gen 2 intake? Did it ever end up making any power, or is it just sound? Ive searched for ever and still haven't found a solid answer or any independent Dyno charts on it. Anyways could you PM prices for gen 2 & gen 3, along with the pully. Thanks
wakeboardr116 is offline
Old 02-18-2009, 06:21 PM
SOLISIMO
SOLISIMO's Avatar
headers to 33321
SOLISIMO is offline
Old 02-18-2009, 06:27 PM
Kev@US-Autotech
PM sent ..
dyno for Gen. 2 Intake ----> http://www.stillen.com/product_files/402843~dyno.pdf
Old 02-18-2009, 06:37 PM
Kev@US-Autotech
Originally Posted by SOLISIMO
headers to 33321
PM sent
Old 02-18-2009, 08:37 PM
Kev@US-Autotech
All PMs replied
Old 02-18-2009, 11:46 PM
808MIKE
808MIKE's Avatar
PM sent!
808MIKE is offline
Old 02-19-2009, 12:28 PM
Kev@US-Autotech
Originally Posted by 808MIKE
PM sent!
PM sent
All PMs replied
Old 02-19-2009, 02:06 PM
djkymar
djkymar's Avatar
Pm the price for pulley and intake 2nd and 3rd gen to 18015
thanks
djkymar is offline
Old 02-19-2009, 04:32 PM
Gyoza
Gyoza's Avatar
PM price of Gen3 intake shipped to 30062
Thanks!
Gyoza is offline
Old 02-19-2009, 04:55 PM
n_jay888
n_jay888's Avatar
PM price for gen 3 intake, swaybars & splitter shipped to 91344. Thanks.
n_jay888 is offline
Old 02-19-2009, 07:00 PM
Kev@US-Autotech
thanks
Thanks!
PMs sent to all
Old 02-19-2009, 10:28 PM
Kev@US-Autotech
All PMs replied
Old 02-19-2009, 11:16 PM
ProstylezG37
ProstylezG37's Avatar
sway bar S model shipped to 70601
ProstylezG37 is offline
Quick Reply: Special *** STILLEN *** Exhaust, Intake, Pulley, Camber, Toe Arms, & Sway Bars ********
