Need help - Brake Switch
Old May 2, 2019 | 06:37 PM
flipmode007's Avatar
flipmode007
My car starts but I can't put the gear into the drive position.
My break light does not work at all also
I went to the dealer and they said it may be the break switch, they gave me this part number 36011-CA000 for my g37xs 2009. But I received this item but when I looked online it doesn't look like that can someone tells me where does this part goes tks. Car has been parked for 3 days now
Attached Thumbnails Need help - Brake Switch-1556836367941.jpg   Need help - Brake Switch-1556836385161.jpg   Need help - Brake Switch-1556836399443.jpg   Need help - Brake Switch-1556836415419.jpg
Old May 2, 2019 | 09:15 PM
Redgoyabean's Avatar
Redgoyabean
Dont know anything about that part number or your issue but you can still drive your car by simply popping the little tab on the shifter n then use something flat n push n hold in the shifters override while changing gears, it's a temporary fix but you still get to drive. Good luck hope it helps.
Edit: check your fuse box, possibly the dealer over looked it. There's a brake light fush some people remove to do burnouts, I would start there.
Old May 3, 2019 | 01:36 AM
flipmode007
Thank you very much, and that's exactly what we did and we checked all the fuses again and we found the culprit, the stop lamp fuse was not working. I should kick myself in the *** a million time.
Old May 3, 2019 | 05:30 AM
Redgoyabean
Lol it's all good just glad its resolved.
g37_black
Mar 13, 2019 11:16 AM
mariio
Mar 11, 2019 12:45 PM
Randallimus
Feb 22, 2019 05:19 PM
Nwcwu
General Tech Questions
Feb 11, 2019 12:58 AM
G10
Feb 7, 2019 02:12 PM
