rwd rear sway bar on awd sedan
Learn to use the vehicle’s weight transfer and use it to your advantage... slow is smooth, smooth is fast. Even a chubby girl can move out!
So far so good
Great improvement overall. understeer is gone. Noticed improvement in turns. Used same brackets new bushings and new rear links.
I actually did this to my 2013 G37x coupe a few days ago and it does help but for some reason It seems as if the front end now seems a little unbalanced when I hit bumps going around curves/corners I’m really not sure what it could be but I’m almost considering going back to stock :-( I got my bar off of a 370z maybe that bar is thicker than a G37s idk any ideas or suggestions???
I felt the same when I had a nismo 370z rsb installed. I ended up getting an alignment and it fixed the issue
emyrl
Apr 8, 2018 12:02 PM
ClassyPump
Nov 2, 2017 07:46 PM
mjnoles1
Dec 18, 2015 10:19 PM
Damn Dirty Ape
Jul 22, 2013 09:39 PM
Genseven
Aug 11, 2010 05:30 PM
