G37xS Coupe Swift Springs
Old Mar 5, 2019 | 01:52 AM
Said Amir's Avatar
Said Amir
Hello everybody, just wanted to share my experience with the swift springs, as their isn't many posts about the g37x coupe, but a lot about the g37x sedan. So far the springs are really nice, really loving the ride, and getting a bit used to it. The ride I actually really smooth, it is not rough until you start hitting some bumps at higher speeds, but nothing that will break your back. I installed the springs my self, and it is a PITA if you do not have anyone else to help you, specially when installing the front shocks. I did replace my old shocks as they had 87k miles on them with KYB shocks, and struts. Rather do it all at once than twice. I also highly recommend getting rear camber arms / toe bolts, but the front camber arms can be really up to you. I also have a square set up on Niche Targa with (19 x 8.5) +35 offset all around with (245/40/19) tires. So far the car looks good, haven't bottomed out, nor scrapped. If you have questions feel free to ask. Also thank you too Blnewt, Hashim, and DustU for helping me.
Before alignment with swift springs
Both my front camber was at -1.9 degrees, and toe at 0.24 degrees
RR (camber: -2.3)(toe: 0.10) LR (camber: -2.0)(toe: 0.62) (reason for it being 0.62 degrees is because I installed the toe bolt that day).
After alignment
RF (camber: -1.9)(toe: -0.03) LF (camber: -1.9)(toe: 0.01)
RR (camber: -1.50)(toe: 0.09) LR (camber: -1.4)(toe: 0.05)
Before
After
After
Old Mar 5, 2019 | 01:01 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Your #1 Infiniti Vendor!
Great review!
If anyone's interested in a set of Swift Springs, contact us!
-Josh
Old Mar 6, 2019 | 08:46 AM
Said, G looks great, and nice writeup/review. DO you have a part # for the KYBs?
Old Mar 6, 2019 | 12:22 PM
Said Amir's Avatar
Said Amir
The front left struts #E6111JK50A, front right strut #E6110JK50A, and rear shock #E6B10JK50A. Got them from rockauto.
Old Mar 6, 2019 | 02:33 PM
slartibartfast's Avatar
slartibartfast
Because it's my nature (for better or worse) I'm going to note the G doesn't use struts. They are separate dampers, unlike McPherson struts used on FWD cars. And anyone selling dampers for the G calling them struts is just plain wrong. It's definitely widespread but it's still wrong.
Old Mar 6, 2019 | 03:41 PM
Baadnewsburr's Avatar
Baadnewsburr
good job on the suspension work, G's looking good man!
Old May 14, 2019 | 05:23 PM
MH2013's Avatar
MH2013
I sent you a message with a question about the AWD KYB.
4DRZ
Nov 7, 2015 08:32 PM
jsp872
May 14, 2015 01:13 AM
Need 4 Speed
Brakes/Suspension
Jul 16, 2014 01:52 PM
awais
Dec 27, 2012 11:37 PM
TVPostSound
23
Sep 30, 2012 08:32 PM
