Clean car after installing new brakes?
Old Feb 5, 2019 | 05:50 PM
mjnoles1's Avatar
mjnoles1
You all are going to think I am crazy with this question.
But I just got new brake pads and rotors. Does the lubricant/grease, pads and/or rotors need to wear in any prior to getting them wet with water from hose while washing my wheels?
Old Feb 5, 2019 | 06:02 PM
Baadnewsburr's Avatar
Baadnewsburr
nope, whatever greased used will wither have enough water resistance to not wash off at all or it will wash off an hour later or a month later...brake grease lube tends to be very tacky and resistant anyways so I wouldn't worry about it.
Also the only parts that need to stay greased/lubed are the contact points between metal surfaces and only exposed grease/lube should wash off (if it does at all) which doesn't matter anyways
Old Feb 5, 2019 | 06:57 PM
JSolo's Avatar
JSolo
Just say no!!!!!
To the OP, you'll be washing the car/wheels often if your new pads are the type that produce lots of dust . Assuming of course this actually bothers you.
Gnomercy1337
13
Jan 16, 2019 09:59 AM
HS125
Feb 11, 2016 11:27 AM
BlackSedan6MT
Jul 26, 2014 03:49 PM
willstophe
Feb 23, 2012 11:06 PM
