How much $$$ should a brake job be?
Old Jul 23, 2018 | 02:51 PM
chesty51355's Avatar
chesty51355
I have a 2013 G37 IPL Convertible at ~48k miles. Was quoted for a brake job by a local mechanic:
- New Akebono Pads
- New OEM Rotors
- Oil change (synthetic)
the total comes out to $1200ish. Seems high. Is that the standard or am I getting jipped?
Old Jul 23, 2018 | 02:57 PM
Baadnewsburr's Avatar
Baadnewsburr
Seems kind of high, but may depend on where you are as shop rates based on geography...brakes and oil change don't require any kind of special knowledge or tools, any mechanic should be able to do them...say 3 hours of labor plus parts...parts can be anywhere between 300 to over a 1000 depending on what's being used...
I'd say an average for that work is probably about 600.00-800.00
Old Jul 23, 2018 | 03:06 PM
Lego_Maniac's Avatar
Lego_Maniac
Are you 100% positive you need rotors? Seem's kinda low miles to need new rotors.
Old Jul 23, 2018 | 03:43 PM
KidJai06's Avatar
KidJai06
That seems high to me too. Miles also seem low for rotors, I'd think unless they are warped or very unevenly warn that they could just be resurfaced. If you have any mechanical know-how and access to some generally basic tools its a pretty straight forward DIY. You could source pads and rotors yourself for a fraction of the price.
Old Jul 23, 2018 | 07:01 PM
G8RDave's Avatar
G8RDave
A quick Google search shows under $100 per OEM rotor and under $100 per Akebono pad set (1 front and 1 rear). So $600 max in parts. $80 for the oil change. $500 is a lot in labor for a 30-45 minute job.
Old Jul 23, 2018 | 07:13 PM
stealthee's Avatar
stealthee
They are going to charge book time for a brake and rotor change.
$500 is actually average or better for a brake and rotor change at a shop.
Want to save money? Do it yourself.
If I remember right my mom took her previous Rogue in for an oil change, check up, etc. They told her she needed new brakes and rotors and quoted her well over $700 all in. She smartly told them no, and when she showed me the quote I laughed hysterically. I found a complete set of brakes and rotors on eBay for $130. I put them on myself and only charged her dinner.
Old Jul 23, 2018 | 07:16 PM
yoda466's Avatar
yoda466
I put new OEM Nissan rear pads (purchased on eBay) on my car for $65 DIY. Took all of 30 minutes. The rotors were fine so I left them alone.
I think brake jobs have become a rather common scam.
Old Jul 23, 2018 | 07:18 PM
yoda466's Avatar
yoda466
Anyone know why my signature says “left left”? I am new.
Old Jul 23, 2018 | 07:36 PM
Lego_Maniac
$500 really isn't that bad. If it's so easy, you should do it yourself
I'd just make sure those are OEM blanks and not junk Chinese rotors.
You have the centering off somehow Edit your profile/sig. And don't clog up other peoples threads with newbie questions
Old Jul 23, 2018 | 07:39 PM
yoda466's Avatar
yoda466
Sorry. Doesn’t seem like a particularly busy forum, and seemed pretty low key and friendly so far. Maybe I was wrong.
Old Aug 7, 2018 | 05:01 PM
G8RDave's Avatar
G8RDave
I actually just did my own. In my driveway. Pads and rotors all around. $500 is way too much in labor for 8 bolts and 8 pins, especially if you have a lift. The rear rotors were a bit stuck, but popped off easily enough with the proper encouragement.
Old Aug 7, 2018 | 06:40 PM
G8RDave's Avatar
G8RDave
Maybe you are more liberal than you think?
Old Aug 7, 2018 | 08:09 PM
yoda466's Avatar
yoda466
Talking
ok, now that’s funny right there. Thanks.
Old Aug 8, 2018 | 03:24 PM
slartibartfast's Avatar
slartibartfast
That's formating code to left-justify the text. Something you did when creating your signature?
Leardriver
Aug 18, 2020 01:52 PM
ONEighty
Lighting/Cleaning Products
38
Feb 28, 2019 04:59 PM
Banshee
Nov 2, 2016 08:55 PM
carlos27
Oct 16, 2016 01:52 PM
