Pic of 1 inch dropped Sedans (preferably AWD)
Old Dec 5, 2014 | 09:55 PM
Razorr's Avatar
Razorr
I ordered a set of coilovers a few weeks ago and it has been sitting in my house for a long time. After ordering, initially I planned on putting them on in the spring, but the wait is killing me.
Can you guys post pics of your lowered sedans? Please mention how low did you drop and how often do you scrape.
PS: This is not my DD, so I changed my initial plan and thinking of dropping it before the winter.
Old Dec 5, 2014 | 10:57 PM
This is about the mildest drop on Tanabe springs, about an inch F&R
Old Dec 5, 2014 | 11:00 PM
And a couple more
Old Dec 5, 2014 | 11:07 PM
Here's a couple threads too~
https://www.myg37.com/forums/g37-sed...or-sedans.html
Big one on 35driver, it's G35s but 2nd gens so the looks are the same
Data Base: Lowered with Aftermarket Rims/Tires - G35Driver
Old Dec 5, 2014 | 11:47 PM
Razorr's Avatar
Razorr
Thanks a lot for the info. I guess I'll just go ahead and drop it already.
Old Dec 6, 2014 | 08:11 AM
No problem.
Most COs are set up pretty low in the back, even at their highest setting. If you want the mildest drop I'd set up the rear first, leave about 1/4" more than the spring thickness on the rear adjustment collar. Once you get the rear set to it's highest setting then adjust the front height so it will be even or slightly lower. The one look you DON'T want is the front higher than the back. My COs even at their highest setting drops about 1.5" in back FWIW. Maybe your particular COs have a higher starting point but in general that's the way most are set up.
Old Dec 6, 2014 | 11:53 AM
tbulsara's Avatar
tbulsara
this is mine,
lowered on D2 Racing Coilovers.
I do scrape on some speed bumps.
I lowered it to where the top of the wheel wells both front and back at 26" from the ground.
Old Dec 6, 2014 | 01:52 PM
Dj1ofDet's Avatar
Dj1ofDet
Same as above, I do scrape on some speed bumps but usually when I go too fast over them. I'm a little over 1.3 inches in the front, and 1 inch in the rear.
Old Jul 13, 2018 | 03:17 PM
botlfed98's Avatar
botlfed98
Swifts 2007 g35x sedan
Attached Thumbnails Pic of 1 inch dropped Sedans (preferably AWD)-img_4405.jpg   Pic of 1 inch dropped Sedans (preferably AWD)-img_4402.jpg   Pic of 1 inch dropped Sedans (preferably AWD)-img_0908.jpg
Old Jul 14, 2018 | 10:35 AM
Baadnewsburr's Avatar
Baadnewsburr
Swifts, AWD... cant remember the last time i scraped anything
AronG37
Jul 31, 2017 07:15 PM
SeanM93
Apr 27, 2017 09:20 AM
ClassyPump
Nov 13, 2016 05:25 PM
N50
The EX - Crossover
Aug 16, 2007 08:21 PM
