Spacers and Springs Help
Old May 11, 2018 | 11:30 PM
ahmedhussain23's Avatar
ahmedhussain23
Exclamation Spacers and Springs Help
Hi today is my first day on here. I have an 08 g37s coupe and i am looking to but spacers and springs rn. i am looking at h&r sport springs and h&r spacers. i was going to get 25mm all around but idk if my springs will affect anything. pls help as to what size should be okay
Old May 11, 2018 | 11:45 PM
Hi Ahmed, welcome to the site. H&R springs are a deep drop spring, in order to keep alignment proper you should also get a full aftermarket camber/toe adjustment set. Unfortunately this is about $500
. If you go w/ a milder drop spring you might be able to get decent alignment w/ just a rear kit, which is about $200.
I would get your G lowered, aligned, then reevaluate how much spacing you want.
Also keep in mind w/ your 08, if you have original dampers you might consider going w/ coilovers, you can get Tein Basis Z coilovers for a couple hundred more than springs, and this will allow you to get just the drop you want, and be riding on brand new dampers.
Old May 12, 2018 | 02:28 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Your #1 Infiniti Vendor!
Contact us for any assistance!
Swift Springs
H&R spacers
SPC camber arms..
-Josh
geazy37
18
Apr 18, 2018 01:33 PM
mikesamson
Mar 10, 2018 12:26 AM
VRG37S
Jun 17, 2017 01:09 AM
